LSJ Downpipe Installed on 2.2
Well I just got done installing my new LSJ DP on my 2.2. Currently I have the racing solution shorty 4-1 header and a Corsa sport cat-back. The LSJ DP was a really good way to finish off the exhaust! I felt a difference as soon as I pulled out of my driveway. And the car really pulls quite a bit harder from 5000-6500 RPM.
Check out the difference..
This is a very cheep solution for any 2.2/2.4 owner that needs a downpipe.
Keep in mind that this is only a direct bolt on for G5/Cobalts with MANUAL transmissions. the motor sits a bit different with the automatic transmission.
I got my LSJ DP from another member for $50. and i have an auto too and it makes the dp sit a slight bit lower and my dp will scrape on big speed bumps. But every worth getting tho.
Yep its just a tiny little thing (thats what she said anyways.. )
So did it directly bolt up? I heard its about 2-3 inches too short for the auto's
No doubt! I didn't think it was that small until i held it up to the LSJ DP lol
Yep I have the racing solution 4-1 shorty header for the 2.2 - LSJ DP - Corsa sport cat-back.
I have noticed a big improvement from stock! the biggest jump was from the header! Its amazing what it did for my top end..
I'll get one. All I have is a shitty camera though. So it won't be the greatest quality. and I'm sure it won't so it any justice.. but it sounds mean!
i did header, then dp then exhaust, i think the best gain was from the dp. the header made a good differance, but i think the dp made the biggest gain. hohonestly the cat back just made it louder, i really didn't notice much of a gain, then againe i swapped cat backs in the middle of a 2 week rain period so it ook awhile before i could beat on it after so i don.t have a sameday comperison.
You're the only person I've heard mention the issue with the auto and LSJ DP...if there's any truth to it not fitting, then I'll have to look into the ZZP mid lenght setup again, but can anyone else say for sure that it will fit with an auto?
I would assume so, but please tell me it will.
I don't want the Cobalt to wind like my old Saturn SC1 where they made a CAI, but the catch was it only worked with manual trans, auto were stuck with SRI unless they custom made one because of the tranny filter.
No issues at all? I have found on both 2.4s and 2.2s with autos the LSJ didn't just bolt in...what cat-back do you have?
the LSJDP is shorter and the cat sits on the sway bar without some adjustments.
Can you post some pics of your install?
Check out my thread, and I have run into this on an another 2.2 auto equipped LS:
https://www.cobaltss.net/forums/show...&highlight=LSJ
