Lsj Downpipe Question
Does anyone know if the Lsj downpipe fits onto a 07 2.2 without mods. I know that the lsj pipe fits on an 06, just wondering if anyone has put one on a 2007. Thanks.
so you have the secondary air injection(SAI)? if so, than no, but if you dont that it shoudl bolt right up, seeing as how u alreay have the lsj header...wait...lsj's dont have SAI, and the 07's come stock w/the lsj header...so it shoudl work...unless someone wants to chime in...
The stock downpipe has a sensor right after the headers, but the ss downpipe doesnt, and im kinda pissed, cause i waited like 2 weeks to get it. I really hope it works, but i dunno.
07 have the same header as the LSJ except you will prob have SAI. SAI will have no affect on if you can attach a downpipe, it only limits your options for headers.
So what I am saying is... hook that puppy up, its a direct bolt on.
read below
some of the 07's have 2 cats on the downpipe, as well as 2 o2 sensors instead of one. so, will it fit? yes, fitment should not be a problem. you'll have to do one of 2 things with the 2nd 02 sensor though:
1) Weld a bung for it
2) eliminate it entirely.
i know for a fact that fitment/installation is possible, because i know someone that has done it.
read below
forgot some of the SAI DP's have 2 O2 sensors (wow too many abbreviations) so glad i flashed mine out.
i THINK only the 07's have 2 o2 sensore on the dp though, guessing because of the sai. i found this out from looking at a g5. no one had heard of it at that point, so i would say it's safe to assume that it's only n the 07's with sai
so, to answer your question, it should fit perfectly.
Yea my downpipe has 2 o2 sensors. But when i look at the pictures of the Sai and i look at mine, It doesnt look the same. There is no tube running into my airbox.
ok. then in that case, fitment will be fine, you just have to get a bung welded in for the 02 sensor to have a home. if it's not in it's home, it gets a little cranky
does anyone know what will happen if i drive my car around with that o2 sensor disconnected? im gonna have the bung hole for the 02 sensor added this friday. i didnt know that the old downpipe had 2 o2 sensors. i just had the ss/sc downpipe and catback installed 2day. also does anyone know how much getting the o2 sensor hole will cost, so that i dont get ripped by the exhaust guy thanks
