LSJ>L61 throttle body pin out
ok where did the pics go? i cant find them, i know they are in someone thread, but i forgot who and searching doesnt help to much :p i know someone had the pin out for them, i think it was hunterkiller, but like i said, can no longer find them, can someone post them? and label which one is the 2.2's and which one is the 2.0's?
thanks
thanks
no he never re did his TB, interview is running stock TB...hmmm...i found some in hunters thread, but i dont know which one is for the lsj or which one is for the l61
found those in hunters build thread, now which on is the lsj and which one is the l61??? i dont have wires on the lsj TB, just the TB itself, and it should clip on with the existant clip, so i just need to cut and re-wire, so i need to know which one is 2.2 and which one is lsj so i cut and swap the right wires :p
This is the one from the LSJ.
Throttle Actuator Control (TAC) Module
Connector Part Information
OEM: 15326836
Service: 88986255
Description: 8-Way F GT 150 Series Sealed (BK)
Terminal Part Information
Terminal/Tray: 12191819/8
Core/Insulation Crimp: E/A
Release Tool/Test Probe: 15315247/J-35616-2A (GY)
Throttle Actuator Control (TAC) Module Pin
Wire Color
Circuit No.
Function
A
D-GN
485
TP Sensor 1 Signal
B
L-BU/BK
1688
5-Volt Reference - 2
C
BK
2752
Low Reference
D
PU
486
TP Sensor 2 Signal
E
YE
581
TAC Motor Control - 1
F
BN
582
TAC Motor Control - 2
G
GY
2701
5-Volt Reference - 1
H
BK/WH
1704
Low Reference
OEM: 15326836
Service: 88986255
Wire Color
Circuit No.
Function
A
D-GN
485
TP Sensor 1 Signal
B
L-BU/BK
1688
C
BK
2752
Low Reference
D
PU
486
TP Sensor 2 Signal
E
YE
581
F
BN
582
G
GY
2701
H
BK/WH
1704
Low Reference
