LSJ throttle body into an L61
So if your doing a supercharger swap or just putting an LSJ throttle body onto an L61 motor that already has an 8-pin throttle body, would it be necessary to repin the harness to match the LSJ throttle body or is it a simple plug and play?
what is TF, but yeah my friend is in the midst of his SC build but his throttle goes straight to WOT when he starts the car, he didn't rewire the TB so I was wondering if maybe he needed too
ok. But I know that if you put an Le5 tb on an L61 you won't need to repin anything but do you think you would from an l61 to lsj (provided it is the same amount of pins just gotta re arrange them)
Even though the pin count is the same you will need to repin.
https://www.cobaltss.net/forums/2743036-post2.html
-or-
https://www.cobaltss.net/forums/4263539-post14.html
-or-
do you need to repin anything if you just buy this plug and play le61 to lsj TB Adapter.... no right >?
6 Pin to 8 pin LE5 harness to LSJ Throttle Body Adapter - eBay (item 290451311795 end time Dec-01-10 17:20:01 PST)
