misfiring
If its misfiring itll run rough, basically.
It will only flash the MIL if the misfire is severe.
If the misfire is persistant you get a MIL(CEL) and set code/codes between P0300-P304.
Have you kept on the maintenance? Do you use TopTier fuel or an additive like Techron at every oil change?
well when i went to skool today i took my dads truck and he worked on my car so and my dad removed this little rubber piece on one of the rubber boots so they all looked the same and it seemed to do the trick it runs fine at stop and go and on the expressway so i think we got it with out having to do anything real major or expensive
Sean Cummings
03-09-2018 12:26 AM
Getaway_Driver
09-08-2015 09:41 AM
