My 2.2L Build Thread (300+ hp)
Old 10-18-2008, 06:49 PM
  #51
HunterKiller89's Avatar
ok....so basically, the idler on the LSJ is in the same spot as the tensioner onthe L61. thats why i was conbfused. i thought both were idlers.
Old 10-18-2008, 06:53 PM
  #52
o3nisoaso3's Avatar
Originally Posted by Preston
G8 GT is a mid to high 13 second car.
your definatly capable of hitting that.
i can get 13.9s with my 2.2 n/a
Old 10-19-2008, 12:00 AM
  #53
brandon2.2's Avatar
does someone make all those pulleys aftermarket for the LSJ I could use, like lightweight versions?
Thats probably what I'll try so I dont have to alter the belt
and I think I might go with the 8.9:1 pistons, and use a 2.5" pulley, or even plane the heads like 20 - 50 thousands to up compression. Has anyone ever tried to shave the head on an ecotec?
OK I found MRZ's crank pulley and alternator pulley for the LSJ, they have a semi-generic alternator pulley that comes in 6 rib
now to find the others
Old 10-19-2008, 12:02 AM
  #54
Sentry's Avatar
I thought shaving the piston head would only decrease compression?
Anyways, you can get pistons custom built for your application in 10.0:1. I believe wiseco can do that for you.
Old 10-19-2008, 03:33 AM
  #55
Maven's Avatar
I dont know anyone who's done it(probably a reason) but Ill go out on a limb and say you can not shave an ECO head by .050"
Also shaving the head to increase compression is silly, youd just be weakening the head, and youd actualy most likely spend just as much on off the shelf pistons and head work as you would on custom pistons.....I am pretty sure JE does custom pistons for the ECO for like $80/ea, or $120/ea with full rings/pins kit.
Old 10-19-2008, 04:21 AM
  #56
alanoo's Avatar
We shaved it 1.4mm (.055"), it works perfectly but I won't do it for boosted apps.
Starting with 8.9 pistons, you can use SiValves valves (less dished), add 0.5 of CR, you're already almost at 9.5, play with head gasket thickness (like the cometic LSJ .027" one) and you may gain a bit again (although I still cannot get a confimation of the OE hg thickness when compressed)
Old 10-19-2008, 09:21 AM
  #57
brandon2.2's Avatar
ok, I'll probably just have to get custom pistons for my application. No big deal, so I have a better parts list with what pulleys I need now and things of that nature. I'll look into diamond or wiseco for custom pistons
Old 10-19-2008, 11:49 AM
  #58
o3nisoaso3's Avatar
i head my head shaved 7/1000ths more than the stock gasket size to new gasket size to up it im prob around 10.5-10.7:1 with compression
Old 10-24-2008, 10:04 PM
  #59
brandon2.2's Avatar
ok well I guess shaving the head will be more trouble than its worth.
I was planning or possibly planning on using the LSJ oil pan as it holds more oil. Would this be worth it? and will the stock oil pick-up be fine?
Old 10-24-2008, 10:13 PM
  #60
tru2nrtt777's Avatar
I honestly have no clue what you mean by "Shave" and "Plane". In my machine shop we Surface heads and blocks but only for warpage or 0.000 deck clearance. I do not know what oem Deck clearance is on our engines but I definately wouldnt do it more than .025 for head/block. Most modern 4bangers come stock with .010 deck clearance or less.
Old 10-25-2008, 01:19 PM
  #61
Maven's Avatar
The LNF uses 5qts = answer.
Old 10-25-2008, 01:50 PM
  #62
brandon2.2's Avatar
haha awsome answer, thanks!
Old 11-07-2008, 06:21 PM
  #63
brandon2.2's Avatar
Update
I just gathered all my suspension parts over the last month.
eibach sportlines
FE5 shocks/struts
TTR rear sway
MRZ strut bar
FE5 front sway bar
HELLZ yea, I am not putting it all on until I get wheels. I got good deals on all of this, managed to find most of it used, but barely used thanks to CSS.net members
these are the wheels I will probably get, one or the other....
http://gravanatuning.com/1514/38/46/...e_2.2_FWD.html
the senond ones are more expensive but weigh the least
Old 11-08-2008, 05:47 AM
  #64
Jn2
Jn2's Avatar
good luck with this...
Old 11-08-2008, 06:09 AM
  #65
hope you plan on using meth with a 2.5 and dont waste your time with 42s. get 60s
Old 11-08-2008, 06:48 AM
  #66
Haz l33t wheelz.
ls1fbody's Avatar
the LSJ system holds 6.5 quarts, not sure on just the oil pan. correct me if i'm wrong, cuz i know you will
pretty sure he said 2.8, or 2.7 at the absolute smallest. Meth wouldn't hurt, especially because nearly everyone running under 2.8 has it, with the stock LSJ compression, so any higher and it would be almost necessary
edit: 07metallicSC, saw the post about 8.9:1 and the 2.5 ignore me.
Old 11-08-2008, 07:45 AM
  #67
brandon2.2's Avatar
I am going to try my hand with just dual pass and ZZP h/e or CX racing h/e and a 2.8 pully.
I will buy a modular pulley system and slowly work down to the 2.8, but no lower than the 2.8 probably.
I'll see as the time comes. I have already ported the outlets of the intake manifold a little bit with a dremel at work, came out pretty good. I am doing some work to the supercharger on monday when I have overnight duty.
OH and thanks JN2
Old 11-08-2008, 08:16 AM
  #68
Sw4y1313's Avatar
With this build you should be going with a TVS and a 2.9 pulley. Dont sell yourself short with a M62!!!
Old 11-08-2008, 10:57 AM
  #69
Maven's Avatar
Youre better of just switching to turbo if you decide you need a 1320......
Old 11-08-2008, 05:15 PM
  #70
^ true story ^
Old 11-08-2008, 11:33 PM
  #71
brandon2.2's Avatar
yea I'm going for a little bit of a budget build. M62 = cheapest FI
and I want to see what I can do with the M62, after porting it and replacing the bearings, I want to see how it will perform (ceramic bearings, suppose to produce a little less heat/parasitic loss)
the M62 will work for me
and yea, if I was going to drop a larger amount of money on the FI portion, it would be a big fat turbo with a lot of boost and lower compression, but thats not the direction I am going with this build
Old 11-09-2008, 03:22 AM
  #72
Maven's Avatar
Brandon, are you getting the Motegis second hand or from Gravana? because tirerack is over $200 cheaper for the track lites.......
Old 11-09-2008, 12:24 PM
  #73
brandon2.2's Avatar
holy ****, your my best friend Maven
I looked at tirerack before and didnt think they had real good prices, so I didnt really look at them too often
Old 11-09-2008, 03:30 PM
  #74
Maven's Avatar
Always have to look, for most part they are pretty competitive, some product they are expensive, sometimes they have really good deals.Ive bought lots of tires from them, I almost always get them next day even when I select ground because they have a warehouse in Delaware.
Old 11-09-2008, 04:44 PM
  #75
brandon2.2's Avatar
and I just found their "view on vehicle" feature when you're looking at wheels, pretty freakin cool.
I even found another set I like that are even lighter and cost the same
Quick Reply: My 2.2L Build Thread (300+ hp)
