My new catback
Steddy stop being a tool, you know youve got nothing for that Veeeeeeedub.
Once we put this true dual catback on my Balt this weekend Ill give you my old exhaust and we can put it on your TC, then you can call out Head Dick over there, youll be able to run probably 3-4psi more boost and a lot more timing with my exhaust on....shoudl get you over 325whp/370wtq with a sweet t00n
Ill be happy to take that off your hands if your not using it
Turbo, Ball Bearing Garrett GT4508R (aka GT45R) . Capable of close to 1200HP! Compressor wheel diameter is 108mm exd. / 80.8mm ind. (56trim) Compressor housing is .69 A/R has a 6" inlet and 3.5" outlet slip on connection. Turbine housing uses a T4 divided inlet and 4" V-band outlet.
Turbine
-Wheel: 87.0mm w/ 85 trim
-Housing: 1.01, 1.15, 1.28, 1.44 A/R
-Maps
Compressor
-Wheel: 108.0mm exd./80.8mm ind w/ 56 trim
-Housing: .69 A/R
yummy!
Turbine
-Maps
Compressor
-Housing: .69 A/R
yummy!
