My Pacesetter Review
Old 09-10-2009, 11:17 PM
Fastone's Avatar
I have the pacsetter Header on my 2.2 Eco Sunfire,I got the ceramic coated one,And 5 years later its still looking good...As far as cracking goes,if you are using a header of any sort you should always use better motor mounts and tranny mounts..But i will buy another one when i need to..
Old 09-11-2009, 08:29 AM
NexTnmE's Avatar
If I cut the stock downpipe, could I use an exhaust clamp for the donut flange that comes with the header until i get it welded?
Old 09-12-2009, 12:09 PM
Fastone's Avatar
Yes You can..Just get it welded soon,Also I would add a flex pipe instead of using the soilid one..Will take off some of the stress to the header..
Old 09-15-2009, 09:29 AM
TurboTechRacing's Avatar
X2 add a flex... The Turbo Tech Racing mounts help a TON also to remove engine movement.
Old 09-15-2009, 10:06 AM
NexTnmE's Avatar
I was reading over the instructions that came with the header, and it says to cut the stock d/p in two locations? I will not get it to fit by just cutting the upper flange off and putting on the donut flange?
If anyone has experience (detailed) on how to use the stock downpipe with minimal welding, that would be great.
Old 09-16-2009, 01:46 PM
Jn2
Jn2's Avatar
TTR mount FTW, i just installed mine over the weekend, man...hahah when the AC is on i can feel the diffrence lol, def helped with wheel hop, now if only there was a magic solution to wheel spin :p
only do the cut at the top, right at the weld were the pipe meets the cat...ignore the bottom cut...its for removing the downstep on the dp to match te catback...or if you have a catback go ahead and have it all welded, but its not a requirement
Old 09-16-2009, 01:59 PM
NexTnmE's Avatar
awesome. thanks!
Old 09-20-2009, 11:49 AM
Lee89's Avatar
I honestly hate to say this...but i have the lsj SC manifold and down pipeon my car....and I love it!!! But for everyone saying that they would rather have the lsj manifold....Its exactly the same as the stock ls lol. Just a different bung location for the sensor. Hope this helps some peoples opinion.
Old 09-26-2009, 09:08 PM
007CobaltLS's Avatar
The LSJ mani IS NOT the same as the 2.2 mani...the primaries are larger, the collector is not D shaped like the 2.2 mani, and it will give a little bit of an increase, just not nearly as much as an aftermarket header/dp. Now whether it's worth it or not is up to you.
I can get an LSJ mani for $25 locally and because I'm auto, I would go aftermarket DP for an auto...but if I'm doing that, I may as well just spend the extra money on the aftermarket header as well. I'll be going with Vibrant, ZZP, or Racing Solutions (probably ZZP). I have an LSJ cat-back to be installed when I get around to buying my header/dp...got that for $45 locally, can't beat that price. Performance increase for minimal money is always good (even if that increase is minimal or just a little more than minimal).
Old 09-26-2009, 09:36 PM
xander40's Avatar
about how much of an increase would you expect with the lsj cat back? it's 2.25" right? and than mine (2.4) is 2"?
dennis69
10-20-2015 04:49 PM
jas09ss
09-26-2015 01:06 PM
Danny Reed
Drag Racing
08-31-2015 10:55 PM
Gravana1
Gravana Tuning
12
10-02-2006 08:46 PM
Quick Reply: My Pacesetter Review
