my supercharger build
#76
from a dig tell him to start in L and brake boost and see what happens. tell him after it goes into second when its time to switch into 3rd to put it into "I" or "2" whatever his console says he shouldnt need to go into "D" well depends how far u guys run haha. oh idk if he has traction control tell him to turn it off.
#77
lol he does all of that and I wont race him from a dig casue he had drag radials at the strip and on the street he has much better tire than I do.When I get better tires ill race from a dig and weve done every roll from 20-80 and on.I pull em no matter what.And his gears are waaaaaayyyyy longer than mine.my 2nd goes to 55.3rd to 90ish.He knows how to drive his car is what im trying to say.
#88
No it is not needed.
#92
correct as long as it reaches and does not kink.when I was NA I had the 2.4 mani so I had to extend it.If it doesnt reach you can always cut the quick disconnect off,get a male to male hose fitting and extend it to the blower then clamp it on.
#98
No,My intake is made from Spectre peices.I have the Spectre MAF adapter tube to mount the MAF,and also the Spectre tube that has ports in it for vacuum hose.Any specific LSJ SC intake has this port included.My build was done on a super tight budget so alot of things are custom like the intake,upper hose,Heat exchanger plumbing,Option B tank.Probably more but cant think of it.
