my supercharger build
#127
yeah i just gota huge amount of parts for cheap lol now im dead broke till pay day but i do need some parts....do you know if the alternator bracket is a must? what all parts do u have
#129
oh hmm ok ill make sure to find one of them also lol iv still got plenty of time i need 3 gauge pod another gauge unsure what to get lsj tb and connector , one step colder plugs alternator bracket and just the lil small things oh and a oil catch can
#130
this is what i got:
manifold
manifold gaskets
brake booster hose
ic pump connector
throttle body
all bolts bought
dual pass endplate
Fuel injector rail with injectors and sensors
alternator
idle pulley
Radiator hose
ic pump
ic pump brackets
TB gasket
tb bolts
stage 2 belt
tensioner pulley
alternator bracket
tripple pillar
volt gauge
boost gauge
sparkplugs
bypass
I just need a intake and the heat exchanger,also gonna get a catch can for the hell of it
manifold
manifold gaskets
brake booster hose
ic pump connector
throttle body
all bolts bought
dual pass endplate
alternator
idle pulley
Radiator hose
ic pump
ic pump brackets
TB gasket
tb bolts
stage 2 belt
tensioner pulley
alternator bracket
tripple pillar
volt gauge
boost gauge
sparkplugs
bypass
#131
yeah i dont have any of the gaskets bolts or hoses was it hard to find the right sizes of the bolts and hoses? also what other type of gauge could i get iv got the wideband and boost maybe volt or vaccum..also im not longer doin the dual pass so yeah. buy whats the bypass?
g11 i think it is is sellin a lsj h/e on here for 70 shipped
#138
well when i bought the kit the little black can thing on the blower was broken so i had to buy a new one,its called a bypass something.you can the the majority of the bolts from lowes the only one you gotta order are the ones for the alternator( i actually have spares if you want).I havent bought the hoses yet.I would go with the volt gauge just cuz i have alot of leds in my car.Im gonna get a cheap intake from ebay.55 bucks shipped lol
the bottom one stays open the top one connects to the blower
Last edited by zerosk8ter83; 02-21-2011 at 05:06 PM. Reason: Automerged Doublepost
#140
Its a boost actuator.Similiar to a turbo wastegate.It bypasses boost while your cruising then gives full boost at WOT.The bottom hose you leave open as its only used on LSJ's.And like I said,if you have True Value where your at they'll have all the bolts you need including the alternator bolts.
#141
lol the bottom tube stays open doesnt connect to anything thats wierd but ok ha
well how much would u give for a modded lsj intake? unless ur content on the ebay one ha
how many alternator bolts do you need two? and if you got them pm me and ill buy them save me the headache of ordering th em
#142
#147
ok lol the intake came with the kit i bought together so thought bout gettin a aftermarket one instead and selling this one...does any1 have a list of what size hoses and bolts ill need iv found like 3 diff. list with diff. sizes lol
i pm;d u bak
i pm;d u bak
