my supercharger build
Old 02-22-2011, 12:59 AM
  #176
1LowLS's Avatar
Originally Posted by heathkidder
hey im auto but im an 08 so will mine fit if not i need to learn how glowbalt did his lol
yes yours will fit.
Old 02-22-2011, 01:02 AM
  #177
heathkidder's Avatar
ok i may learn how to do it the other way also so i dont get any surprises
Old 02-22-2011, 02:18 AM
  #178
Originally Posted by zerosk8ter83
MAP To Intake Manifold
M6 x 1.0 x 25 (Qty 1)
LSJ Intake Manifold Mount Bracket To Intake Manifold
M10 X 1.50 x 50 (Qty 1)
LSJ Rear IC Pump Bracket To Intake Manifold Mount
M8 X 1.25 X 25 – (Qty 2)
LSJ Front IC Pump Bracket To Rear IC Pump Bracket
M8 X 1.25 X 35 – (Qty 2)
LSJ Idler Pulley To Alternator Bracket
M8 x 1.25 x 25
LSJ Intake Manifold To Block
M6 x 1.0 X 75 (Qty 2)
M6 x 1.0 x 25 (Qty 5)
LSJ Alternator Bracket To Block
M8 X 1.25 X 130 (Qty 3)
LSJ SC Bypass Valve To SC
M8 X 1.25 X 20 (Qty 2)
LSJ Tensioner Lower To Alternator Bracket
M8 x 1.25 x 35
LSJ Tensioner Upper To Alternator Bracket
M8 X 1.25 x 40… not standard bolt though. Has to be metric hex socket bolt.
LSJ SC Reservoir Bracket To SC
M6 x 1.0 x 15 (Qty 2)
LSJ SC Reservoir To SC Reservoir Bracket
arnt you missing bolts?
such as the lsj intake mani mount to block?
lsj sc to intake mani bolts
lsj tb to sc bolts
lsj idler pulley to block
lsj intak mani bolts
arnt these needed as well that arnt on the list
Old 02-23-2011, 04:28 PM
  #179
zerosk8ter83's Avatar
so how much psi are you looking to push?
Old 02-23-2011, 04:54 PM
  #180
1LowLS's Avatar
70
Old 02-23-2011, 08:43 PM
  #181
lol atleast 10-12 can any1 answer the question about the bolts
Old 02-23-2011, 08:51 PM
  #182
Glowbalt's Avatar
yes lol..Must've cut off when I copied and pasted...just look on the build threads.
Old 02-23-2011, 08:53 PM
  #183
i have every1 has different ones like sum have certain ones that others dont ? lol
Old 02-25-2011, 09:24 PM
  #184
UPDATE: i now have about 90 percent of the parts mainly need gaskets bolts and hoses idler pulley tb and tb connector 3 gauge pod another gauge and oil catch can .... wheres a good place to get the oil catch can and gaskets???
Old 02-25-2011, 09:32 PM
  #185
try ebay
Old 02-25-2011, 09:36 PM
  #186
Axelthered05's Avatar
gaskets you can get from ZZP
Old 02-25-2011, 09:38 PM
  #187
eff ebay lol and thanks ill check zzp out
Old 02-25-2011, 10:36 PM
  #188
1LowLS's Avatar
My catch can is ebay.and came color matched too!
Old 02-26-2011, 01:23 AM
  #189
nothing wrong with ebay.zzp is on ebay
Old 02-28-2011, 10:58 PM
  #190
yeah ill prolly get the oil catch can from there lol
are u only using one h/e?
also can u use stock alternator
Old 02-28-2011, 11:39 PM
  #191
1LowLS's Avatar
Yes Im using the factory alternator.It is multi-directional so that can stay.And Im using only one H/E but its the huge OTTP unit.And my catch can came with a braket,which bolts to where the fatory air box bolted down.
Old 02-28-2011, 11:59 PM
  #192
sweet i seen some oil catch cans ill prolly pick one of them and i have the cobra h/e that should do fine lol
Old 03-01-2011, 12:05 AM
  #193
1LowLS's Avatar
Ya cobra H/E are good.
Old 03-01-2011, 12:06 AM
  #194
im going with the zzp H/e looks pretty cool
Old 03-01-2011, 12:07 AM
  #195
yes it does. cobra came with the kit i bought so i may keep it im undecided
yeah thats what i heard so i was pumped to hear i was gettin 1 with the kit
Old 03-01-2011, 12:08 AM
  #196
have you got anything else for your build?
Old 03-01-2011, 12:14 AM
  #197
yeah i got everything but bolts and gaskets and idler pulley and alternator bracket and 3 gauge pod
Old 03-01-2011, 12:18 AM
  #198
the alternator bracket is gonna be a bee ouch to find
Old 03-01-2011, 12:21 AM
  #199
i almost got one but didnt yet lol im sure i can get it new if it comes to that
Old 03-01-2011, 12:38 AM
  #200
1LowLS's Avatar
For shizzle
Quick Reply: my supercharger build
