mystery engine light
I was out last night in a freak snow storm, happen to glance down and see my CEL light pop on. It came on, stayed on, and hasn't gone out. I'm at a loss. It's not in limp mode, everything is running perusual, my gas cap is tight, engine is idiling fine.
The only 2 things I can think of that might trip be at fault is a dirty air filter or my fuel. I checked my air filter(stock air box type), not overly dirty, but I'll pick one up off my next pay.
The only other thing I can think of is that I got gas at a different station then usual and maybe that station uses different additives then my usual station??
Should I try re-setting the code by pulling the battery wire? I don't have the 50 bucks to get it read right now, any thoughts?
You can try adding a fuel injector cleaner to your next fill up sometimes it will turn the light off on occasion even though it doesnt actually fix anything it helps in keeping the engine as clean as possible. Or you could just replace the pre-cat 02 sensor. How many kilometers or miles do you have on the car?
dunno, but it went out. I have 72,600km's on it and it's an 06 g5. I'm thinking it was a combo of gas cap and the last place I got fuel, having shitty fuel. We shall see.
cruise control works, now that thermostat wouldn't surprise me at all, cause it takes for ever for me to get heat, even when the car is warmed up and display is saying 95-110C. And yes it's a 5spd.
I'm going to track down someone with a code reader cause the cheapest place I can find to read the code is 50bucks+taxes. I damn near **** when I called the dealer and they wanted $50 to start+min of 1/2 hr = minimum of $85+taxes just to plug in the reader.
There has to be a place around here that will pull my code for free.
50 bucks for a code read? That's beyond lame. My S10 threw a code last week so I just went to Autozone to borrow one. All I had to do was put down a deposit. Its too bad Canadian Tire won't do something like that... they're big enough, sheesh. (Damn I miss Nova Scotia.)
if he has sai he has 2 cats on the dp if not he only has one anyways i had a check engine light too about 6 months ago the car was running perfect no problems whatsoever when i brought it to the stealership they said one of my cats wasnt working so they got me a new one
i think what happened was the same thing that happened to me last winter
i hit a little snow rut and broke on of the plugs under the car. the cel light was on and everything took it into the dealer and they said a sensor what broken, and they fixed it and it went out.
car ran fine and what not.
last i had the car running the cel light was on too but thats cause of the home made cai.
my wintr beater has had the cell light on now for 5 yrs lol
