need help finding tach wire
i've gotten a lil help from ion ninja but i can't figure out exactly which one, im probably wrong, but i tink the colors are a lil different in the ions. Can anyone help me out to find the tach wire that i can tap in on for my traction control switch? thanks
Itz okay now. I took a closer look and decided to pul the wires out of the loom and found that the little peice that ws visible changed colors from the heat. I got it on now. I have a new problem now...it doesnt read my RPM right. It reads it, but just half of what it is. So if im at 3000rpm is show 1500rpm. so i set it up that way and it works fine. I would like it fixed though. If anyone can help. thanks. im not sure what it is...it might be my power source, i have it hook up to itz own cig lighter. or it might be the connection on the actual tach wire, im pretty sure tz hooked up good. i dunno at this point.
what do u mean 2 cycle? Like the gears skipped or the tach signal setup?
I got it workin. I changed the tach signal setup and it works fine now. thanks.
agentirons
10-16-2015 02:11 AM
