need help plz
need help plz
ok i made a custom cold air right..well i first had a short ram and everything was working perfect well i made it in to a true cold air all the way down to the vent .. well then as i started it up and started driveing it start puttering and wanting to die(at idle speed) but as soon as i hit the gas i runs like a raped ape! Help plz
Check to make sure the intake is securely attached to the throttle body...both clamps tightened down and the silicone boot is all the way up on both the intake and the throttle body. Pop ur hood and look where the intake meets the engine, you'll see what I'm talking about
