Need some help with my SC build
Ok so I have a lot of the parts that i need to supercharge my l61. I have the Supercharger, LSJ intake manifold, LSJ throttle body, ZZP S1 heat exchanger, 42lb fuel injectors, and the IC pump. I was just wondering exactly the intercooling system works. For example do I mount the S1 heat exchanger in front of my stock radiator if so exactly how do I do that and also what exactly is the option B kit? Any info would be much appreciated especially pictures.
Yes mount the S1 heat exchanger in front of your stock radiator. with brackets from the hard ware store, the brackets that came with it, zip ties... whatever to make it stay.
Option b is just another h/e reservoir if you use a different than stock reservoir to begin with and plumb the system right you dont need an option b kit.
Option b is for bleeding air pockets out of the fluid to help the coolant temp.
