new ** MRZ Performance UDP and Lightweight Crank Pulleys for the 2.2/2.4 NA Ecotec's
Old 09-05-2008, 02:03 PM
Black07SS's Avatar
definately will be a purchase once i see proof of their worth. is there anyone willing to do testing on a 2.4?
Old 09-05-2008, 02:17 PM
Jn2
Jn2's Avatar
if we had a 2.4 in our area i woudl talk them into, but all we have r 2.2's and 2.0's...
also after searching i found what the trq spec for the crank pulley bolt is, which is very important to have
first pass= 74lbs-ft/100 n-m
second pass=75*
Old 09-05-2008, 02:21 PM
Black07SS's Avatar
i would do it if i had access to a dyno. unfortunately right now there is only a dyno or 2 in the city im from but i just moved to a city of 10,000 people which barely has a garbage dump.
Old 09-05-2008, 02:56 PM
MRZ - RedGTZ's Avatar
Arrow
Originally Posted by IonNinja
so whats the deal with the whole harmonic balancer issue? no one has ever been able to provide a solid answer on this.
Our pulleys are fully CNC machined from a solid billet aluminum bar witch makes them perfectly balanced witch is not the case with the OEM cast iron pulleys that need balancing due to uneven repartition of the material/weight. That said, there is no additional vibrations transmitted to the crank and crank bearing since they are both perfectly balanced.
The vibrations that can be transmitted to the crank are the vibrations from the accessory belt but they are the same on the billet pulley or the OEM pulley since the harmonic on the OEM piece is located inside the pulley itself and not outside like on normal crank pulleys. Take a look at an Ecotec harmonic when it's off the engine and you will see what I'm talking about. That said. Both pulleys contacts the crank and belt directly, so our pulley will transmit the same vibrations as the OEM cast iron pulleys.
I do agree that the best thing will always be to have a true harmonic balancer on an engine with a rubber insulation to cut the belt vibration from the belt. This way of making it is very costly however since 2 parts are needed, vulcanizing, balancing since there are multiple parts assemblem with rubber. This kind of part would sell for a lot more...
Originally Posted by Jn2
i changed my sig, fully functional ur side links to ur site, TTr links to TTR
Nice sig you got there
second pass=75*
Yeah, we provide the torque specs with the instructions as well to be sure the install is done correctly
Last edited by MRZ - RedGTZ; 09-05-2008 at 02:56 PM. Reason: Automerged Doublepost
Old 09-05-2008, 03:12 PM
iLLmaTic3s's Avatar
i wud get em..if they were free to test on the 2.4 and go down and dyno them at my friends shop..oh well
Old 09-05-2008, 03:33 PM
Borderlin3's Avatar
Ok, so this is NOT recommended for a supercharger application? What about cooling mods?
Old 09-05-2008, 03:40 PM
the lightweight is perfect for supercharged application
the UDP is NOT recommended for supercharged application
Old 09-05-2008, 04:21 PM
Borderlin3's Avatar
Oh, I didnt read it well enough to realize you had two products for sale in your post. my b.
175 BONES!!!!!! yikes. not anytime soon.
Old 09-05-2008, 06:45 PM
Gearblock's Avatar
waiting for numbers, then im in
living in montreal, i wanna support MRZ lolol
Old 09-05-2008, 08:15 PM
tru2nrtt777's Avatar
If we were getting dyno results for you do we get a discount? I have a friend who may allow me to use the his shop's dyno...
Old 09-05-2008, 08:39 PM
  #36
Jn2
Jn2's Avatar
im already on it testing both the underdrive and the lightweight pullies, will provide how-to install with pics, and vid of dyno, and sheets of dyno's
Old 09-05-2008, 08:43 PM
  #37
^^^Darn, forgot you were a 2.2
Old 09-05-2008, 08:47 PM
  #38
njg5gt's Avatar
pm sent about 2.4 testing...
Old 09-05-2008, 09:00 PM
  #39
Jn2
Jn2's Avatar
i run SS/Na times if you feel better
Old 09-05-2008, 11:57 PM
  #40
CobaltLT's Avatar
Any chance of a group buy?
Old 09-06-2008, 01:03 AM
  #41
Maven's Avatar
The crank pulley is not a "harmonic balancer" its a harmonic damper. The ECO engine doesnt require the crankshaft pulley to be weighted and act as a "balancer" since the engine is internally balanced. So reducing the weight of the pulley is fine and should obviously result in freed power.
It does however need a a pulley equipped as a damper to absorb/dissipate crankshaft torsional vibrations. There is nothing we can do about these vibrations other than dissipate them in some way(a damper) or just let them happen and risk the consequences. Everytime a cylinder fires it loads the crank, the crank flexes and then unloads, its this constant loading/unloading that we call torsional vibration. All by itself it doesnt sound bad, but ifwhen this vibration in the crankshaft happens at the same frequency as the cylinder firing event there are now massive forces on the crank that it isnt designed to withstand, the damper absorbs these vibrations so that there are far fewer(ideally no) times when the cranks vibration frequency and the cylinder firing frequency match eliminating the possibilty of these vibrations exerting forces on the crank(and bearings!) it isnt designed to take.
The MRZ pulleys look like excellent pieces, will surely free up some power for you and will most likely offer many miles of trouble free service on your ECO. Just keep in mind youre removing an important design feature that virtually every engine in existance designed for endurance uses.
Old 09-06-2008, 11:42 AM
  #42
Borderlin3's Avatar
^^ well then wouldnt getting either aftermarket mounts, or an engine damper thereotically solve the problem once and for all, all the while freeing up more power.
Old 09-06-2008, 12:05 PM
  #43
Maven's Avatar
No, mounts and engine dampers restrict engine movement, we need a cranksjaft damper to dissipate the vibrations in the crank. Imagine the crank is sitting on the table in front of you, if you strike it with a hammer its gonna vibrate, if there was a crankshaft damper on it the vibrations wouldnt last as long and wouldnt be as severe because they would be transfered harmlessly to the outer mass of the balancer through the damping agent(the damping agent, the rubber or fluid in the damper, is what absorbs these vibrations and simply changes most if it into heat)
hit a tuning fork, it vibrates and sings, do it with your hand on the fork end and all you get is a dull thud and minimal vibrations, your hand absorbed most of the vibrations. Your hand is the damper.
All that said, if my plans for an ECO powered Stlaker come to fruition I would like to use one of these(the Stalker would be a minimal use vehicle)
Old 09-06-2008, 12:34 PM
  #44
Jn2
Jn2's Avatar
very interesting, im going to be testing both model on this one, keeping mu stock, i have 35k on my car, with a 72k warranty, so should anything happend im covered, cuz my bud is a tech at the dealer i wonder how long it will be till it causes problems...hmmm...vey very interesting...but still the thought of faster rev'n entrigues me, MRZ i already mad arrangements at my local shop, well nto set in stone appointment, but they now ma go down to yno 3 times, so we came to 150 would cover the 3 runs
Old 09-06-2008, 12:43 PM
  #45
wbrevels's Avatar
sweet, cant wait to see some numbers
Old 09-06-2008, 01:21 PM
  #46
Wow, here it is $50 for 3 runs.
Old 09-06-2008, 04:39 PM
  #47
ei3dag3's Avatar
when he said runs, ment runs, he gets 2 pulls
Old 09-06-2008, 06:04 PM
  #48
But here it is $50 for 3 pulls or $150 for an hour of tuning/unlimited pulls.
Old 09-06-2008, 06:53 PM
  #49
Jn2
Jn2's Avatar
thats nice, i know some places have better deals, but im loyal to this dyno shop, they were the ones that didnt laugh because i wanted to dyno a stock car a while back, no since than i have done all my dyno's with them, i dyno every mod :p
i doubt any big HP gains will occur, but due to faster reving you will reach ur RPMs faster, thus netting you a faster spool, not b/c u spool in lower RPM's, but b/c you get to your spooling RPM's quicker, but i am going to dyno both the lightwheight and UDP, and my bet is i wont say any hp gain, but i will see that the engine will rev faster, think of it as this
set up 1:
2000-6500rpms took u lets say 3 seconds
set up 2(OEM size MRZ)
2000-6500rpms took u lets say 2.6seconds
set up 3(MRZ underdrive)
2000-6500rpms took u lets say 2.4 seconds
in all examples you made the same HP, but its how fast you rev'd that made the diffrence, while i doubt it will add power it will help you make that power faster, thus helping you get down the track faster, hope that helps
i posted that in the 2.4 section, thought i'd post it here too, basically read it, thats what i beleve, i doubt it will add WHP, but i know damn well it will let u MAKE that WHP alot faster...thus helping you get down the track FASTER, now i am still DYNO'n both pullies to see if what/if any HP they make
Old 09-06-2008, 07:00 PM
  #50
The underdrive will add a marginal difference in HP but technically it is considered "releasing hp" not "adding".
Quick Reply: new ** MRZ Performance UDP and Lightweight Crank Pulleys for the 2.2/2.4 NA Ecotec's
