New to the form, but have some question
Sup CSS.NET well im going to try and make a long story short i use to own a 06 ss/sc but about a month its was really windy and a tree fell on my car most of the damage was on the roof so it was a total loss. the car was already payed for so i got a good amount of money and i bought the car back, for i could maybe build it. well i came across a good deal on a 06 cobalt ls with 64k miles i was going to do a ls/ss swap but looks like im going to put a downpayment on a camaro ss instead so as of now my ls cobalt is going to be my daily so i have a couple of question.
1.which vaccuum line do i use to seafoam
2. its a 5 speed how long do you think the cluth will last for normal driving
3.any problems i should be aware of at 64k miles
2. Entire life of the car if driven "properly", even if not, the most I could see a LS with bolt-ons and a tune going through is maybe 1 clutch.
3. At my work, a lot of Cobalt's that come in have lower CAB bushings that are shot.
i dont think so i will check with my local dealer for any recalls by the way wasnt there one on a fuel pump or something
1. Brake booster line. Next to the clutch/brake fluid reservoir, then down and to the right a little. You'll know, as the line traces back to the intake manifold, and it's a pretty big hose.
fuel filter
air filter
oil filter
change oil
spark plugs
any thing else im missing
Air filter: Not sure about this because I have a CAI, but I'd guess like $25
Oil filter: $6 (ACDelco)
5Quarts of fully synthetic: $25 (Mobil 1)
Spark plugs: $26 (ACDelco)
That looks about right to me. Shouldn't take more than 2 hours for everything.
I would, to get it out of the way to get it replaced with updated parts otherwise its like $2,800 worth of parts and labor,check out if the warranty covers that, mine did cuz I still had mint milage on it, around 800, anyways something to do with the electrical powersteering and it locks up sometimes, im usually not a safety freak about things but this is a serious issue especially when ur driving on the highway, if it happens put the car in neutral and start it again while the car's still rolling.
Fuel filter: $55 (ACDelco)
but OP, you also replace your cabin filter around this time. and when you do change your fuel filter remember theres a special tool that you need to get the lines off. after spendin like 30 minutes on my car i said "**** this ****" and came on here for a how to and figured that out lol
