Next Mod..?
Next Mod..?
Ok so I've got the Garrett turbo kit sittin' at home waitin' to be installed, megan coils on the way, headlights coming in from streetazn, girlfriend is buying me Tenzo R's, done a little interior work but nothing special so what next?
I've been planning to order a MPx 3" cat-back but haven't really gone through with it yet.
I've more about performance than anything else really, so lets here some ideas..
if he's on a 07+ block he shouldnt have to unless he's going above 400 (i think thats what the number was, few beers and trying to remember numbers...)
You could always look into a custom exhaust if you want performance/sound, switching between mufflers and resonators and exhaust diameter (just dont buy a "turbo" muffler damn near the most restricting muffler out there)
i'm guessing you're talking about the "turbo" muffler. Its a brand/style that is meant to sound like a turbo (not the blow off exhaust pipe thing) but the problem is it restricts the exhaust like a turbo does.
Click here if you want to learn more about exhaust in general and the turbo muffler
Exhaust Theory
Exhaust Theory
Gen 2 block in 07+ stronger sleeves they dont replace them until you want to break the 400 number.
Heres info from NJHK from ecotecforums
Significant Updates to the L61 in 2007
how is that forum btw?
They say its fine to 400, but i'd be looking into better head studs and def valve springs if you want to get near 400. Although i'm not sure how the head flows stock near that range, for the 400-600hp build they used a sportsman (GM special head, just street pnp'd basically, and some valve seat work).
How much is 93octane across the pond a liter?
i'm on ebc slotted/dimpled and hawk hps pads. they pull the car back from even the highest speeds. only advice i have is to properly bed the pads and rotors or your brakes will be garbage in a matter of months.
i have a habit of pulsing the brakes when i'm slowing down during normal braking. it keeps the rotors from overheating during most driving conditions. once the brake rotors get too hot they warp when they cool down. repeated overheating and cooling will cause the rotors to warp to the point that your steering wheel will shake during braking.
How about doing all your maintenance and making sure everything is up to par.
On top of that, do a compression test before hand so you know where you are before you turbocharge it.
But a lot of the guys on here buy Hawk pads.
PM R1 they're a vendor on here, he'll explain it better and you get a ss.net special price.
