Nitromethane cobalt 2.2l RENTAL!!!
some one needs to get a stock rental car buy a few gallons on this **** and go up to the track and get some times and get us some numbers here! do we have any takers?? lol o yeaaaaa get some video if you do!
Problem 1 = Melted Cat
Problem 2 = Torch O2 Sensors
Problem 3 = HOT LONG Burn = Melt engine parts.
Source 1
http://auto.howstuffworks.com/question642.htm
Source 2
http://www.smokemup.com/tech/fuels.php
*Quote*
But that doesn't mean to go out and pour nitromethane in your car and see how it runs, if you do your engine will surely blow up. Nitromethane is very expensive and dangerous to handle. The interesting alternative to gasoline is Methanol. Methanol will make more power, typically around 20% more power than a similar engine running gasoline. Some things to consider in running methanol is your fuel system will have to be completely changed / upgraded. Based on the table above the fuel system will have to flow approximately 2.5 times as much as the gasoline engine.
Source 1
Source 2
*Quote*
anyway i dont belive the heat is issue we had the air conditiong on and i live in vegas were 105 degrees is normal so both engine cooling fans were running .... keeping temps donw i guess cause we didnt melt **** and after we completely ran it through we filled right back up with gas and mashed on her all the way back to rental facility which was a good 1 hour drive from LAKE MEAD !! anyway simply amazing
Ive always had fantasys about completly suping up an old ford festiva, reucing the weight, no a/c, powersteering, what have you. turbo, you name it, except keep the outside looking like complete **** and then go tear up people in 50,000$ cars. now THAT would be funny
have you been reading this post lol? THIS is what people do to rental cars LMAO
Damn! You put $40 worth of fuel in that thing!?!?!? Atleast thats how much that **** costs here (more for different brands too). That sounds funny, i have wondered what would happen if someone did that hahaha.
