No Acceleration Power!!
Old 09-07-2014 | 02:56 PM
emcheck55's Avatar
Exclamation No Acceleration Power!!
Ok so car has had acceleration issues and throwing P0300 codes, after some prior posts I read I pulled the front O2 sensor(before Cat) and it had lower power but it was running way better and no more P0300.
Then I put it back in, dumped some cat cleaner in the gas tank, and ran fine for a couple weeks.
Started up again so I pulled the O2 sensor again. Rand for about 5 mins like before, then a major power drop and barely limped it home.
Is this just the Cat getting even worse, or is there some other issue potentially that I'm missing.
Also not sure if it's related, but my heater core was leaking, so I bypassed it for now, already ordered a new one.
It's a 2006 LS 2.2L
Old 09-07-2014 | 03:42 PM
Well the o2sensor has nothing to do with that code. Check your spark plugs and your ignition coil
Old 09-07-2014 | 08:11 PM
06_ion2's Avatar
Change the pack ontop of the valve cover.
Old 09-08-2014 | 05:49 PM
Spanky's Monkey's Avatar
What this guy said
Old 09-08-2014 | 06:44 PM
TheSlowGT's Avatar
Originally Posted by spanky's monkey
what this guy said
quincy!!!!!!!!!!!!!
Old 09-08-2014 | 09:25 PM
Helllllllllll yeah! I miss you guys.
Old 09-13-2014 | 07:55 PM
emcheck55's Avatar
Would that cause the loss of power? And if that was the problem would the Cat cleaner I dumped in the gas tank have helped even if it was temporary?
Old 09-13-2014 | 08:03 PM
emcheck55's Avatar
Originally Posted by Spanky's Monkey
What this guy said
Are we talking about the coil pack or the ICM?
Old 09-13-2014 | 10:36 PM
ICM should be no need to replace the whole pack. Paid just shy of $80 for one at the local stealership.
Old 09-14-2014 | 05:41 PM
emcheck55's Avatar
So I found an autozone that actually still tests ICMs, gonna have it checked, it's it's good I'm going to get the coil pack, if it's bad I'll replace the ICM and we'll see how it goes.
Botha parts are each $80 so def only wanna have to buy 1 of them
Old 09-14-2014 | 07:32 PM
REDi DEViSTATOR's Avatar
The P0300 code is common for people. It's the code you get when you haven't owned this car for very long. It's actually just your car reminding you you're driving a chevy.. just so you know.
Old 09-14-2014 | 11:10 PM
06_ion2's Avatar
Yes. I had mine go out around 64k miles. Was around $50 but that was at a saturn dealer.
Old 11-15-2014 | 11:03 AM
emcheck55's Avatar
Update: so I replaced the ICM and it ran good for about 50 miles or so then started up again.
I replaced to coil pack and bingo.
Also just for the hell of it after that I put the old ICM back in to see if it was just the coil pack but the problem came back.
So I had to replace both
Old 11-15-2014 | 02:57 PM
good to hear it's working again. too bad about having to replace both, looks like some of us lucked out.
Zharrington_2010LNF
02-08-2016 02:43 PM
Jimmy Beilfuss
10-05-2015 05:18 AM
Stuff
10-01-2015 06:47 PM
DocSvensk
09-27-2015 03:24 PM
