Nos Installed Check it out IN my VB
#51
with a wet shot that big you would need to upgrade your fuel pump wouldnt you...?
thats what i did and after it was all over i spent around 1100 on my kit. want to be as safe as i can be. now im riding around with it all in my trunk and will hopefully be installing it in the next couple of weeks
ya personally i think it isnt hooked up the way its suppose to me... the nozzle should be 6"-12" away.
i spent about 1200 or so on my kit WITHOUT install... but i got alot of gooodies
bottle warmer, remote bottle opener, n2o pressure guage, n2o command center, blowdown kit, window timer
#52
with a 100+ shot it is a good idea to use this type of setup as you cannot guarantee even distribution through a single fogger kit (wet or dry does not matter) at that size.
and I'm not sure of the limits of the fuel pump but I can only assume that you'd need a higher flowing pump at a 150 shot.
I've yet to see any serious nitrous projects here it kinda sucks, you go over to the Honda forums and there are guys running ridiculous nitrous setups.
#53
direct port kits are always a wet shot, you are injecting both fuel & nitrous into the intake runners to gaurantee an even distribution into each cylinder.
Looks like I am oging to be everyones guinea pig for that big shots lol.
Thanks for the help though man I appreciate it!
#55
Ohhh ok I see what your saying. Just trying to get all of this info together before I buy anything as far as a kit goes. I'll have to ask the guy building my motor, he builds drag cars for a living so hopefully he will know lol. Or maybe i will be lucky and the manifold will be strong enough???
#57
i know it goes to the tps but i dont know what wire to connect it to. i just need to know the wire color that the white wire from my zex connects to.
