Nos Installed Check it out IN my VB
Old 05-16-2008, 04:10 PM
  #51
409Cobalt07's Avatar
with a wet shot that big you would need to upgrade your fuel pump wouldnt you...?
Originally Posted by silentd
ya personally i think it isnt hooked up the way its suppose to me... the nozzle should be 6"-12" away.
i spent about 1200 or so on my kit WITHOUT install... but i got alot of gooodies
bottle warmer, remote bottle opener, n2o pressure guage, n2o command center, blowdown kit, window timer
thats what i did and after it was all over i spent around 1100 on my kit. want to be as safe as i can be. now im riding around with it all in my trunk and will hopefully be installing it in the next couple of weeks
Old 05-16-2008, 05:14 PM
  #52
IonNinja's Avatar
Originally Posted by ORT
But I may just try the progressive route. Seems like that may be the way to go. However, (this is for you IonNinja) Would I still have to run the direct port like you said since it will eventually be a 150 shot?
direct port kits are always a wet shot, you are injecting both fuel & nitrous into the intake runners to gaurantee an even distribution into each cylinder.
with a 100+ shot it is a good idea to use this type of setup as you cannot guarantee even distribution through a single fogger kit (wet or dry does not matter) at that size.
and I'm not sure of the limits of the fuel pump but I can only assume that you'd need a higher flowing pump at a 150 shot.
I've yet to see any serious nitrous projects here it kinda sucks, you go over to the Honda forums and there are guys running ridiculous nitrous setups.
Old 05-16-2008, 05:36 PM
  #53
ORT
ORT's Avatar
Ohhh ok I see what your saying. Just trying to get all of this info together before I buy anything as far as a kit goes. I'll have to ask the guy building my motor, he builds drag cars for a living so hopefully he will know lol. Or maybe i will be lucky and the manifold will be strong enough???
Looks like I am oging to be everyones guinea pig for that big shots lol.
Thanks for the help though man I appreciate it!
Old 05-16-2008, 07:16 PM
  #54
yellowltcoupe22's Avatar
what wire is the white wire from the zex fuel nitrous management box hooked to on the tps.?
Old 05-17-2008, 11:09 AM
  #55
IonNinja's Avatar
yes...or to the white wire from zex window switch if you have one.
no prob, just search google for direct port. you'll find a ton of ****.
Old 05-17-2008, 11:32 AM
  #56
Rent me! per hour
Area47's Avatar
Old 05-17-2008, 02:35 PM
  #57
i know it goes to the tps but i dont know what wire to connect it to. i just need to know the wire color that the white wire from my zex connects to.
Old 05-17-2008, 04:42 PM
  #58
ORT
ORT's Avatar
Originally Posted by Area47
lol that had to be the most random post I have ever seen....leave it to you Area lol
Old 05-18-2008, 12:15 PM
  #59
06cobaltls's Avatar
video??
brandon04
10-21-2015 07:04 AM
dennis69
10-20-2015 04:49 PM
dennis69
10-20-2015 07:39 AM
justinchinn
10-02-2015 12:18 PM
yellow dragon
09-28-2015 09:49 PM
Quick Reply: Nos Installed Check it out IN my VB
