objectif 13s' N/A
#78
i m may be the fisrt one to install a LSJ trottle body on a N/A application cammed
it is not install yet. I ll give a try tomorrow. TFT is off for few days.
thx to ZZP for the adaptor plate and the connector.
#83
it is mine
everything is install and i wont remove it even without a touch up from the eye. i swear on the precious...
if you run a 2.4 TB you ll be able to run it. a 2.2 without tuned that want use it, ll get a power reduced as a 2.4 TB
video ll come..............
third gear pull
http://www.youtube.com/watch?v=uwCj-bV9zo0
2nd gear pull
http://www.youtube.com/watch?v=e325HuOb_H8
third gear pull
2nd gear pull
#85
i said if you actually run a 2.4 trottle body you can run a LSJ without a touch up from trifecta. i wont be optimized but at least you can run this part
zzp has all that info.
http://www.zzperformance.com/products_img/988_2.jpg
http://www.zzperformance.com/products_img/988_3.jpg
#90
not sure how high octane you can get up there but 93 or 91 and a more aggressive tune may do the trick. If it doesn't, a water meth kit and more aggressive after that and you should be golden. That extra power plus those slicks and you should be there.
#91
i thing that i ll get it without meth and etc.
my setup is done. if i dont touch 13,99999999999999999999, just to bad.
i m very happy about huck and his perfo
this is a unique car that people underestimate.
#92
first time of the year with a best time of 14,9
still running my 555r
but still, i had great time today
YouTube - saturn ion cammed - cobalt turbo tune gm pont rouge 2011
#95
no traction even with a 2,151 60'
but i m faster that last year at pont rouge 14,7
my 2010 best time has been achieved at Napierville.
i was severly WRed.
still running my nittto 555r now at 17psi
TOM you are at 96mph......... nice. this is a potential for you to imporve your time
i was severly WRed.
#97
i m installing a 8000 rpm on a stock valvetrain
the goal is to finish my ¼ in third gear.
it is hrd to me to finish in 3 instead in fourth for a fraction of second
i ll be able to shift around 7600 W/O hitting my limiter:
1. 7500
2. 7800
3. 7700 and so
video ll be online tonight.
1. 7500
2. 7800
3. 7700 and so
#98
