objectif 13s' N/A
#103
#104
#106
ok you run a pair.
i m lapping that ź track big time.
i BO in 2nd gear, it take 2 seconds and smoke come out as you fast as you write ''ALLO'' on your keyboard
#108
i bought two rear door for 40$.
i ve tested some WR. was 40lbs and now 20lbs
i ll do lexan glass swap.
objectif 999kg
it is now open by one finger instead to be by a hand
objectif 999kg
#109
took me 7 minutes to swap from stock to drag door
it is a 4 bolts.
no more inside handle. when i open the door from inside, i need to pull on the rod
it is a 4 bolts.
#112
you should do a fiberglass shell for the inside. of the door.. it shouldnt weight that much ..and then do a lexan unlowerable window.. then you'd have a track door.. and it would look much more finished then what you have (not that you probably care about that) but still
#114
for NOW it im working on R&D about shifting. i may need to knif all the gear inside. it is time consuming. but after it ll be papy in mamy all the time
i have 2 options:
- back to stock clutch and pressure plate. i miss that time big time
or
- swap the g5 hydro clutch line for the pedal to the releasing bearing and run a stged clutch
http://www.youtube.com/watch?v=fZhjj3ifXrE
#118
As apposed to the people who buy a factory fast car, get someone else to tune it and then go to the track and still only run 13's. Then come on here and try and talk down to the people who actually have the knowledge and skill to take a car that isn't fast and make it faster.
Which describes half the people on this site.
#119
Some people like the challange of setting goals and then building a car to meet those goals.
#122
since 6 year I ve invested 1000 by years.
it is not that i dont want a TC. i love it.
