objectif 13s' N/A
Old 10-02-2011, 09:16 AM
  #201
huckernage's Avatar
i may have a issue
still need fluid before to start it
but when i put my key at on, i have no batt light, CEL, airbag. i have passlock and my milleage is light on and off.
wiper light fan work
is it a pcm blewup
or do i have a ground somewhere that i ve forgotten
Old 10-02-2011, 04:42 PM
  #202
huckernage's Avatar
i forgot the mean ground from the pcm:
oil
here my helper, remove engine in 2 hour, put it back in 3 hour and a other 4 hour to put right
back to 2009 tune- no more cam stg2
it was ready to start but coil pack and injector were bad. i broken both fuel rail bolt. need to work on it. swap my 2.2 ion fuel and inj. then start rigth away
here what you guy want know
you can see some metal in the oil
this part has failed
Old 10-02-2011, 05:39 PM
  #203
BLKLS's Avatar
So no more cams? Is the bedplate unbolted or did that happen when the bearing spun? Is the a main or rod bearing?
Old 10-02-2011, 05:49 PM
  #204
huckernage's Avatar
no more cam idk about that one but i need a car to get to work
this bedplate fall out when split the block in half
i got a piston ring cracked
all bedplate were all worn down. overall this 2.2 has gave all it can give.
did over 1000 pass over the year. 7500rpm then 8000 for 4 month.
it was lot of fun
Old 10-02-2011, 06:21 PM
  #205
olivecj's Avatar
nice pics huck. cant wait to see some vids with this beast back up and running. do you think you'll do a pass on the new engine?
Old 10-02-2011, 07:19 PM
  #206
BLKLS's Avatar
Gottchya. Any chance on selling the cams lol
Old 10-02-2011, 08:16 PM
  #207
huckernage's Avatar
selling the cam are possible
Old 10-08-2011, 09:38 AM
  #208
huckernage's Avatar
last night i ve installed my cam stg2 back in
cam holder tool
Old 10-08-2011, 05:27 PM
  #209
BLKLS's Avatar
Nice! Couldn't drive with out it lol
Old 10-09-2011, 01:29 PM
  #210
NWAE Cobalt's Avatar
Nice, going back to boosted too?
and ya...your engine failed the same way mine did hahahaha blew the rod bearings :P
welcome to the club :P
im pretty much done trying to squeeze power out of these engines...im getting the feeling no one will make the right parts to keep this thing making power N/A and still be halfway affordable :P
Old 11-10-2011, 05:31 PM
  #211
huckernage's Avatar
i was missing a master piece. here you go. boost ll be back as soon as i can. boost is worst than drugs.
this setup look like a turbo setup with the intake air going down
is it to low from the ground?
btw here my lastes vid against boost car
http://www.youtube.com/watch?v=Pw8keZW_ujE
http://www.youtube.com/watch?v=fg2Z6HQMiHY sorry about gopro sound
Old 11-17-2011, 09:18 PM
  #212
huckernage's Avatar
reinstall everything tomorrow
i ve bought better oil. i ll test mobil one
i ll run a Heat exchanger this time
but i dont know if i have to uncammed it.
sound good a SCed cammed. this is unique
Old 11-19-2011, 12:56 PM
  #213
huckernage's Avatar
boost is good
saturn ion cammed SC cluster - YouTube
saturn ion cammed SC wideband 11,7-12 - YouTube it weird, because my AFR ws leaner on my 180K engine.
saturn ion cammed SC - acura type S chiped - YouTube i m shifting at 6200
Old 04-14-2012, 05:17 PM
  #214
huckernage's Avatar
testing some go pro view after reflashing my worst TC ever. sham on hahn intake
rear view and side view. ion 2.2 sc - cobalt tc trifecta - YouTube
Old 05-12-2012, 03:26 PM
  #215
huckernage's Avatar
saturn ion cammed and SC AFR: 10,8-11,6 2012 may - YouTube
Old 05-13-2012, 11:04 AM
  #216
olivecj's Avatar
sounds good huck. when you going to the track again?
Old 06-10-2012, 08:38 AM
  #217
huckernage's Avatar
still love my SC cammed.
updated for new purchasessss. not installed yet
duel and plate
second fidanza plate
option B
here a little video from last night with our 82th reflashed
saturn ion cammed SC - cobalt 2010 TC tune trifecta (jonW) - YouTube
Old 06-11-2012, 06:02 PM
  #218
IonNinja's Avatar
What RPM is your redline at with the Stage 2 cams?
Do you have stock balance shafts?
Old 06-11-2012, 09:07 PM
  #219
huckernage's Avatar
mhmmmmmmmm
i thing at around 7500 and so. hard to say since i needed to remove all my needle.
still stock intern.
but have some issue about get leaner when my radiator fan kick in
Old 06-11-2012, 09:11 PM
  #220
huckernage's Avatar
actually i have a pair stg2 to sell for 350 can$
Old 06-25-2012, 04:16 PM
  #221
huckernage's Avatar
i got a duel and plate
a fidanza plate
and option B
anyone has the route to install duel and optionB
thx
Old 07-06-2012, 01:14 PM
  #222
huckernage's Avatar
next step for cooling upgraded
Old 07-06-2012, 03:29 PM
  #223
huckernage's Avatar
it ll be a 2 IN cold for 1 OUT hot
Old 07-06-2012, 03:37 PM
  #224
Thread Killer
FrossB's Avatar
It makes me happy that you have stuck with this project. seem very dedicated! nice job
Old 07-08-2012, 08:55 AM
  #225
huckernage's Avatar
did some work last night.
Quick Reply: objectif 13s' N/A
