p0300 (again) & p0135
Weird thing is, my car throws the p0300 ALL the time...however the CEL light on the dashboard never goes on. Everytime I scan the car however, p0300 is displayed...very awkward...I delete the code each time but by the next time I scan the car for codes, it's back up...
p0135 is heater performance bank 1 sensor 1.....I believe that has something to do with the o2 sensor in the header...correct me if i'm wrong
the P0135 code has nothing to do with the cat. it indicates a malfunction in the heating circuit for the front o2 sensor. modern o2 sensors have heaters in them to warm them up faster to get the car into closed-loop operation sooner in an effort to reduce cold-startup emissions.
if you are getting this code, check to make sure that the wiring for the front o2 sensor isn't rubbing on anything (common issue on a car with bolt-ons), if no rubbing, you probably need an new front o2 sensor.
bottom line, a bad cat or even a missing cat will not set this code. it's an issue either with the o2 sensor or the wiring to the sensor.
the P0300 code is most likely caused by your cams. That code will be set if the computer detects a brief variation in crankshaft speed, calculated from the signal recieved from the ckp sensor. The stg 2 cams will cause your engine to run rough at idle, which makes the computer think there is a misfire, but won't be able to trace it to a specific cylinder. Otherwise you'd be getting P0301, P0302, P0303, or P0304 along with your P0300. Running those stage 2 cams without tuning is bad idea, but i guess not a huge deal if you don't mind some odd behavior from your engine.
figured something like that. i dont have a cat and figured the 2nd o2 would go off... ive been looking for a new 1st one
car is tuned and idles 800-900ish
Would a lightweight flywheel give you a P0300 code? I just had one installed, and now I am throwing that code. I've never had that before.
If it is the flywheel, I wonder what we can do about it, short of removing it. And I'm definately not removing it.
That would be annoying not passing emissions because of a CEL due to a non-emissions part.
I know my 2.4 was throwing the same code po300 with my cai, what was happening was at the car wash the under carrage wash got the filter just at the tip and water or condesation would keep making me throw the code. If you have a cai I would check the filter. When I checked mine out it was barely visable but I did see the water stain and it looked dry. Now that I changed to the K&N it hasn't came back Remember it only take a little moisture to throw the code. At least that was in my case.
i have been throwing it for quite some time now. mine came right after i put on my hahn catback, or maybe my header i cant remember. either way it could be caused by too little back pressure maybe. i also need to work on my tune so it could be in there somewhere.
its probably a mix of a whole bunch of different things that can cause this code. id say that everyone is probably right with their problems but im not a tech so idk
Mine sets the 0300 all the time . Clear it , its back within a day . Ive never been able to figure it out as I dont have any issues . Wierd thing is if I change my plugs the code goes away for a few thousand miles before it starts setting again I do have a aluminum flywheel , no clue if theres a corralation . I dont recall 0300 starting to set after I put the fylwheel in .
