p0300 (again) & p0135
This is something I found. Hope it helps.
CHECK ENGINE LIGHT ON, DTCS P01 71, P0300, P1174 SET (PERFORM INJECTOR
TEST, REPLACE INJECTORS AND REPROGRAM ECM, IF NECESSARY)
TECHNICAL SERVICE BULLETIN
Reference Number(s): 08-06-04-001B, Date of Issue: April 21, 2009
Affected 2006-2007 Chevrolet Cobalt, HHR; 2006 Pontiac Pursuit (Canada); 2007 Pontiac
Model(s): G5, G6; 2006-2007 Saturn ION; with 2.4L Engine (VIN B, P - RPO LE5)
This bulletin is being updated to include the Pontiac Pursuit and to add an Supercedes: Important statement. Please discard Corporate Bulletin Number 08-06-04-001A (Section 06 - Engine/Propulsion System).
Related Ref Number(s): 08-06-04-001, 08-06-04-001 A, 08-06-04-001 B
ARTICLE BEGINNING CONDITION
Some customers may comment on the check engine light being illuminated.
A scan tool may reveal DTC P0171, P0300 or P1174 set as current or in history.
CAUSE
This condition may be caused by the plugging of one or more of the injector director plate orifices which results in a lean condition.
CORRECTION
IMPORTANT: This condition cannot be corrected by cleaning the injector(s).
IMPORTANT: For Chevrolet and Pontiac vehicles, reprogramming must be done using the remote method.
For Saturn vehicles, reprogramming must be done using the pass- through method.
Follow the published diagnostics in SI for any DTC recorded.
Perform an injector balance test using the Active Fuel Injector Tester (AFIT), CH-47976. Refer to the Fuel Injector Diagnosis (w/CH47976) procedure in SI. If any injector is identified as having a lean condition, replace all four injectors with the revised injectors. After installing the new injectors, reprogram the ECM with updated calibration files using the TIS2WEB Service Programming System (SPS) application. There are two calibration part numbers that are valid for "Engine Operation". Select the part number with the description that reads for vehicles with second design injector. The injector has a dark blue overmold color for this repair.
IMPORTANT: The fuel injectors must be replaced and the new calibration files must be installed to ensure a complete repair. Failure to perform both repairs will result in the customer returning with the same condition.
If a vehicle returns with the same condition after having this repair performed, the technician should first verify that the complete repair was performed before continuing with SI diagnostics.
PARTS INFORMATION
Parts Information
Part Number Description Qty
12625029 Injector, Fuel 4
WARRANTY INFORMATION
IMPORTANT: For claims to be paid, injector balance test results must be recorded on the repair order.
For vehicles repaired under warranty, use: Warranty Information
Labor Operation Description Labor Time
J7808* Perform Injector Balance Test and Replace
Injectors (Includes Programming) 1.0 hr
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
© 2008 Mitchell Repair Information Co., LLC.
also idk if i said this before but my car used to not throw the code if i didnt let it sit to idle (always held 900rpm minimum). but now ill never see that yellow lite again lol
