P2433.... new problem HELP
ok, so the other day a CEL pops on and i assumed it was the lean code yet again,s o i ran it with my code reader and a new code was on the list.. P2433 which is Sec Air Inj Sys Air Flow/Pres sensor circ high bank 1... what does that mean, and what the hell can i do to make it go away.. my car is up for inspection this month and i want it gone by the time i go in for it... if it matters i just put on the CA downpipe, which it should not make a difference right?
Thanks in advance
Thanks in advance
It means that your secondary air injection is malfuntioning. It should be covered under warranty. Take it to your dealer.
Secondary Air Injection is a little pump that injects air into the exhaust to help with the chemical change in the cat. It's not a big deal, you can live without it.
i know what it is, and i think i found the problem.. i got mad at it when i was installing my ingalls... so i shoved it like.. out of the way, and the hose worked its way into a kink, today i undid the kink and the light went away.. hopefully for good
