part are finally coming together
Im soon to begin my turbo build for my 2.2 and i have a list of parts...if there is anything i should add or not use let me know
hahn exhaust..ported and polished head by SMG...oversized valves(1mm)...zzp retainers...zzp springs...eagle forged rods...clevite rod bearings...wiseco 8.9:1 pistons...cometic head gasket...comp cams turbo grind...balance shaft delete...vulcan intake many with i belive ls4 throttle body...aem wideband...boost gauge..oil pressure gauge...arp head studs...solid motor and tranny mounts...spec stage 3+ clutch and exedy flywheel...and of course a zzp stage 2 turbo kit(didnt purchase yet dont know to go with stage 2 or 3 any input??) have the cash though
let me know wat you guys think can get some pics soon
DO NOT delete your balnce shafts unless u like getting ur fillings replaced. Itll rattle them right out of ur teeth. I rode in a ss with that and it was retarded. Notthe good retarded. Totally was not enjoyable.
Just cams alone with solid mounts do this. Also you could just run a 2.4tb less work without rewiring. Thats what i have on my vulcan intake mani.
jcalvin1126
09-11-2015 10:24 AM
