The Phantom Grip Limited Slip
Old 07-02-2008, 08:44 AM
MadBrad's Avatar
"PHANTOM GRIP XTREME UNIT The Phantom Grip Limited Slip conversion kits install into your non-lsd differential converting it into a proven and competitive limited slip differential that enhances your traction needs. Phantom Grips 2-way LSD will considerably improve handling in daily driven, street/strip warrior, or full race vehicle. Every Phantom Grip is constructed of only the highest-quality hand selected materials. With over 500,000 miles of vigorous professional performance testing (SCCA, drag, rally, hill climb, ice, rain, etc.), we have been able to fine tune each application through specific heat treating and rockwell testing to achieve maximum performance and reliability. Each Phantom Grip unit is assembled with pressure tested matched sets of progressive-rate springs to achieve equal load distribution to the disc plates, which dramatically enhances reliability and performance. With such a passion for perfection, we at Phantom Grip are confident that when you choose a Phantom Grip unit, you are choosing, by far, the best limited slip conversion kit on the market."
Any 2.2 guys like to try.
http://www.howellautomotive.com/inde...OD&ProdID=2322
Old 07-02-2008, 12:57 PM
TurboTechRacing's Avatar
NO dont use that brand, they are over priced...
Check this out:
http://www.j-body.org/forums/read.ph...=34009&t=34009
They are 10X better quality and cheaper!
Old 07-02-2008, 01:07 PM
invisible's Avatar
Will this work on a ss/sc?
Old 07-02-2008, 02:23 PM
Spanky's Monkey's Avatar
did i read that right? does it really work for autos?
Old 07-02-2008, 05:16 PM
HunterKiller89's Avatar
(note: 2.2 LS manual)
Old 07-02-2008, 05:58 PM
no, the TTR link, not the op link.
Old 07-02-2008, 07:37 PM
YSUsteven's Avatar
Copied directly from the link.
Originally Posted by Team GREEN LSD (F23, F35, 4t40e, NVG) GP
I've been receiving quite a few requests for the LSD's again, so I'm doing a GP on the Getrag (F23/F35), 4t40e/4t45e auto, and NVG (internal slave) LSD Inserts.
Doesn't it state that right there.
Old 07-02-2008, 07:42 PM
Fire_Starter's Avatar
Next purchase, Aaron when are you guys going to vendor for em so I can pay with a cc?
Old 07-02-2008, 09:15 PM
i smoke crack as a past time just making sure those there rocks aren't foolin' with me brain, thanks bro.
Old 07-02-2008, 11:15 PM
Let us know, we personally know Brian, and Team Green, we can get you one if you would like. Anyone interested PM us. I believe they have test fir them already on the F23 manual, F35 manual, and the 4 speed cobalt auto
Old 07-02-2008, 11:37 PM
lil_kano's Avatar
subscribed...
Old 07-02-2008, 11:40 PM
pimpnwink's Avatar
i might be down but then again ugggh a bit flustered with what i want to do in a years time the TTR link not the first one.
Old 07-02-2008, 11:42 PM
Let us know if we can be of any help...
Old 07-02-2008, 11:52 PM
Ok Aaron, I need one for a 2.4 auto, thats the 45e? I forget to be honest.
Old 07-03-2008, 07:03 AM
Jn2
Jn2's Avatar
hmmm. i dont have traction problems, but it would be nice to throw a LSD on anyway, to bad im not in the mod to spend that much on one...
Old 07-03-2008, 07:42 AM
LSD kits help also A LOT with pulling you around corners, (in a very good way)
Old 07-03-2008, 09:51 AM
RedBaseBolt's Avatar
I have an LSD Insert. It's just not installed in the car yet. It looks like good quality though.
I believe it's from Green Performance. Not 100% though cause I bought it second hand but the guy never installed it.
Old 07-03-2008, 11:07 AM
Sw4y1313's Avatar
What does it cost to have this installed? can one do it themselves without too much trouble or what? If so i WILL buy this like next paycheck...
I am sure it is Team Green, which is the same as we are talking about getting them from
Old 07-03-2008, 12:03 PM
Yeah thats them.
It's a good quality piece. very HEAVY for being so SMALL.
Old 07-03-2008, 12:50 PM
IonNinja's Avatar
so what exactly is the difference between these inserts and an actual LSD because I don't hear alot of positive things about inserts as opposed to Quaife LSD for example
Old 07-03-2008, 12:54 PM
Luv2Race's Avatar
Subscribed for later use
Old 07-03-2008, 01:55 PM
The Quaife is better, if you can afford it go for it The inserts are almost just as good, much better than stock.
Old 07-03-2008, 04:32 PM
Buckweed's Avatar
question what the hell does LSD do for our cars?
like whats the difference between LSD and non-LSD
Old 07-03-2008, 08:17 PM
YSUsteven's Avatar
LSD, when one tire looses traction the other wheel will still put power to the pavement.
NON LSD, when one tire slips, it spins, it smokes and you go nowhere.
The average person does not need an LSD. This is why it is usually a factory option on performance related cars, or on trucks and SUVs to assist in towing. The only time I wish I had one is in the winter for driving in snow.
Quick Reply: The Phantom Grip Limited Slip
