Is it possible to remove the catback without cutting?
I need to remove my exhaust to put my new one on is it possible to remove it without cutting it? I know it would be easier to cut it but all I have is a small hacksaw.
Thanks
Thanks
edit: just noticed its a 2.2 not sure if its the same as my ss s/c
i've done it before, twice it sucks, but is possible. like said you have to drop the rear torsion beam. When i did it on my 2.0 we had to pretty much take it off to get the clearance we needed. un-bolting the shocks didn't drop it down enough, even with me literally standing on the rotor and jumping up and down.
word of advice, the torsion beam is pretty heavy, don't try to take it off by yourself. you'll probably drop it and pin yourself under your car. it's awkward for one person, ideally you would have one person taking off the bolts, and 2 people to catch the beam, one on either side. you also may have to disconnect the brake lines so you're not over-stretching them.
thank for the help i just used this mini hacksaw i had it took a while but finally got it
but when i installed the ss/sc catback the ground clearance is horrible it is only 2 inches from the ground, is this normal
if you are lowered it is...ive scraped mine a few times. oh well, what are you gonna do. it sounds purdy tho
Cutting it is a bitch, but if you ask me removing everything else to get a pipe out that can be easily cut is a waste of time. You will probably spend more time taking things off to remove the exhuast then just cutting it to begin with. I cut mine with a small hacksaw, took me about 5 mins to cut through it. Arm hurt like a bitch after cutting it because of the angle, but it was quicker than the other route.
sorry it was a cell pick, but u can kinda see the thing we used to hold the exhaust up on the part that comes done alot, than we welded on the new dp to let it match up, it was funny, cuz he asked if its sappose to do that, i was like, so far al the balts ive seen have that downward curve, some by a bit, and some by alot, he was like **** them, ths is your cobalt, and yours wont have it, than he stared at it and made it all work, it was funny he is a cool guy, i do all my welding there...
if you look at it the right side of the flange(where the 2 bolts go thru) is hgher than the left, not just us of the angel, lok closluy u can see it sitting a bit angled
cut my with sawzall smoked right thru it 10 secs....
yah i had to twist mine a few times after i took a test ride...it was hitting somewhere and riding really low...pita with no lift either
yeh mine is super frikin low to the ground, but i never seem to scrape it unless im traveling to fast into driveways, which usually never happens or if i have a car load. btw if you get the ss/sc catback cut the dang muffler off and get an after market
