Pulley FOR 2.2?
Pulley FOR 2.2?
what site sells the under drive pullies for the 2,2's? i cant seem to find them anywhere?
bumpssss...
bumpssss...
I never really understood the pro's and cons's of each and was wondering if some light could be shed on them?
Lightweight Alternator Pulley - Ecotec 2.2/2.4 - 5 ribs
2.2 2.4 Ecotec UDP - Underdrive Crank Pulley L61 LE5
2.2 2.4 Ecotec Lightweight Crank Pulley L61 LE5
Bump Please!
Bump Please!
thanks very helpful! If i got the under drive pulley is it a must to get the shortened belt? and which one in theory could create more Hp one a modded vechicle?
using lighweight pulleys r about 2lbs less then a stock pulley so it puts less load on ur engine, frees up a free hp if you modded, and helps u rev out faster,
based on way mods i see u hav and r goin to get, a lightweight pully will give u a little gain and yes u need a shorter belt but its just a little short, but do this add a last mod b/c price/power ratio u dont get much
Last edited by hackeragent061; 11-25-2009 at 01:40 PM. Reason: Automerged Doublepost
yeah you wont really see any hp numbers but you will feal a difference I have both udp and alt pulley and the car revs a lot faster and please for the love of god dont buy the shorter belt online go to your local auto parts store and buy one for cheap
By having them lightweight the engine has less of a load to try and turn. This allows the engine to spin faster thus quicker revs and with less of a load more hp(very little tho). Do it more for the revs so you can get to your powerband quicker and thus faster 1/4s!
the gm drag cars run the super damper with no problems up to 1400 hp.
it is already balanced and can with stand high rpm abuse.
i dont know as to how much it weighs but its better made than most
costs bout 410 through summitt racing
Last edited by 06cobaltindallas; 12-01-2009 at 01:53 AM. Reason: Automerged Doublepost
