Purchased the 2.4l intake mani kit.
thats all you've got to do really besides clean a little and put everything back correctly
yea i know i quoted myself
10-15 ish more if i had to guess but its just a guess and with the video as well. but its got a deeper sound to it and pulls a lot better then old one does in the upper rpm's
where can i get a 2.4 mani kit???
and how much does it usually cost?
awesome was gonna install tonight and didnt notice the kit doesnt come with intake gaskets......................................wow now i gotta wait another week or two. where can i get the intake gasket?
aww soo the gaskets i use for this manifold are the little rubber band looking things? i just assumed it would be a big metal intake gasket. yeh my bad... thanks CED for the kit sorry for the confusion.
CED's #1
thank you for your excellent service. doing it in about an hour and a half.
#37
#38
#39
A 2.2 w/the 2.4 manifold, w/exhaust, and w/intake still has more low-end torque than a stock 2.2 -- the touted "2 ft-lbs lower torque" was with all the add-ons too, however, the HP gain (and torque gain) from 3000-6000 RPM more than compensates.
#40
How is that? I thought low end tq went down with those mods only hp went up? So you would have lower tq but higher hp than stock. idk, could be wrong but the mods i have done so far feel like they took some of my low end.
#41
I know that when I had all the mods on my 06LS auto I could put the "pedal to the metal" and get some really good wheel spin (far more than Stock) and the car pulled all the way to the "L" shift point (no not like a 2.0LSC - but for a 2.2 it was nice!). When passing, the car screamed nicely. I have seen 3 dyno charts with the 2.4 intake on a 2.2 and the ranges in HP increase were 9, 13 and 21 HP more at 6000RPM. Personally I don't like dynos because 1. temp and humidity can change the readings 2. Dynos can be "adjusted" by the operator -- I dyno'd my auto and couldn't hold it in 3rd gear (kept downshifting and upshifting as I pushed the throttle) so the operator I had couldn't get a nice clean line on the graph for me to post anything worth looking at to help prove it worked (and I didn't base line it anyway -- at $176 I didn't care to do it again either).
#42
got it all done. i can really notice the loss of low end torque. doesnt wanna fry tire as much as before. but damn after about 20mph pulll is good. ive been keeping 0-60 times after each mod (NOTE: times may not be super accurate but its a good base as to see if your gaining.) and so far stock was 8.91 after CAI and exhaust dropped to 8.44, and after the intake manifold (just did a couple of runs) 8.20
#43
Well that's a pretty nice drop. Helps the 1/4 mile time quite a bit. I finally got a CAI to match my 2.4 intake mani and man this car wakes the hell up. Can't wait for full exhaust. that 145-150 WHP will be a nice difference from stock. Can wait to get to 15.5 in the quarter or less
Still need a little driver mod before i hit the track too
#44
Typically when you have lots of torque, you have less overall horsepower, as this typicaly means you have low end torque. (see a pickup truck) When you typicaly have high horsepower you typically have less low end torque. (see just about any honda)
Horsepower is a function of torque at engine RPM. Thats why the horsepower is higher with high RPM.
What the 2.4 intake manifold does is shift the torque curve higher into the RPM band. This make less torque down low but more up high. Thats where the Horsepower gains and torque loss come from.
A phrase to live by
"Horsepower sells car, Torque wins races."
And as there is only a torque gain north of 4000 RPM, if you drag the car, thats where you run the engine anyway.
#46
Yes the GMPP Performance Intake works with the 2.4 intake manifold on a 2.2L. The throttle body sits more centered on the 2.4 intake manifold -- on the 2.2 manifold the throttle body actually sits about half an inch to the driver's side. The 2.4 intake manifold actually makes the GMPP Performance Intake fit better.
#47
#48
I'm still up in the air about doing this mod. I think I may wait to see what happens with these 2.2 tunes that are being worked on. Perhaps they will find some way to minimize the torque loss and make everyone happy.
#50
these engines need back-preasure to make torque
dont get mad if im wrong, because i really could be
