Purchased the 2.4l intake mani kit.
#52
Gonna have to say this was an awesome mod. i have been driving all night and holy ****, car feels so much faster now, great mod and i highly recommend it. yeh maybe 0-20 mph has slowed a bit but man get ready to be tossed in ur seat till upwards of 70+.
#54
Have you tried driving in I or low yet? It makes a HUGE difference in the performance of the auto. I also have the RSM lightweight pulley, so it helps the car rev a little faster. I have the alternator pulley I bought off of a member on here, but I still haven't put it on yet.
#55
#56
This is a thread on it from the site...
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/light-weight-pulley-31424/
I paid $150 when I bought mine, and now I see it is only $40.
RSM was bought out by z-spec, so they are probably limited to their stock on hand.
It is the same size as stock, only lightened.
I've had mine in since June of '06 with no problems so far.
I've heard good and bad on these, like it can cause vibrations and premature engine wear, but we also have twin balance shafts to reduce vibrations.
I guess just use it at your own risk....
#57
Well that's a pretty nice drop. Helps the 1/4 mile time quite a bit. I finally got a CAI to match my 2.4 intake mani and man this car wakes the hell up. Can't wait for full exhaust. that 145-150 WHP will be a nice difference from stock. Can wait to get to 15.5 in the quarter or less
Still need a little driver mod before i hit the track too
as far as the manifold swap goes it is by FAR the best mod i have done to my car performance wise. i really recomend it to anyone who is thinkin bout it.
as far as times before i was running with the manifold i was puttin up some constant 16.5s trapping around 83-84mph. after the swap i went back and my times dropped to 16.4 at 86-87mph. so there is a def improvement if you run the quarter mile with this mod
and remember..... i have an 07. i have heard of the 05-06s not gettin the gains that the 07-08s are. think about that when deciding on the swap.
#60
#62
I don't have the part number but here is a link to the kit.
http://www.crateenginedepot.com/stor...P1817C137.aspx
#64
#65
Both the 2.2 and the 2.4 manifolds are made from plastic. The 2.4 has a larger plenum and larger runners which pushes the powerband higher. If you are looking for an aluminum intake manifold, be prepared to pay alot. Low to mid boost applications are just fine with the plastic manifolds.
#66
