Putting LNF exhaust manifold on L61 with SAI
Let me start this post saying that this engine is on a track car with a standalone ECU. So emissions and CEL/codes are not a concern.
I have a 2008 L61 that unfortunately has the secondary air injection ports open on the head. I have the LNF exhaust manifold and turbo setup that I am adding to this engine. The problem I have run into is that the LNF exhaust manifold does not cover two of the SAI ports in the head.
What options do I have for blocking these ports? Below is the two that are not blocked by the manifold flange.
All the research I've done, it appears that even the Non-SAI heads still have those little square ports next to the exhaust port, and they are open to the exhaust port. It was just the exhaust manifolds that were different from SAI to Non-SAI.
I figure its going to be tough to get that area clean enough to get a good TIG weld to close it.
Its not a large opening, but its right at the edge, I am worried that a custom gasket may not have enough clamping force out there to seal it.
just use a gasket that blocks the port i use this one
LSJ Exhaust Manifold Gasket [ZZP]
How about that, I don't recall noticing them ports on mine but it's also been, 6 or 7 years since my exhaust mainfold was off. That's a pretty big hole, welding probably is the best bet. Or like three tubes of the gasket maker stuff lol
janinexxmariee
11-29-2015 02:58 AM
