Question to 2.2 owners...
For those of you that own the 2.2 litre, and have put the ss/sc downpipe on your car, did you start out with two oxygen sensors on the stock 2.2 downpipe? One before and one after the cat? I bought a ss/sc downpipe from one of the kansas city guys, and I only see one oxygen sensor bung on the downpipe, but mine looks like it has two. Anything helps. Thanks!
i see that......but what i am asking is if the other 2.2 guys also have 2 o2 sensors on the stock 2.2 downpipe. just wanting to check with people that have done this with their ls or lt models before i go get another o2 bung welded into place. thanks for the quick response though.
What year is yours, they may have changed placement by year, my 06 has one on th emanifold and one after the cat on the DP.
Edit, just noticed it is an 08. If I remember right you should have two on your DP, to make it work you will need another bung welded.
we only have one as well i have an o7
my friends 07 also only has one
one in the header and one after the cat
mine is an 08.....lemme check again to make sure that is not the one i am seeing tru2nrtt777
yeah, definately on the downpipe.....****. thanks guys
Last edited by Firebirdhorn; 09-06-2008 at 01:19 PM. Reason: Automerged Doublepost
60 shipped to 28311?
yes, the 2.2 has both the oxygen sensors in the downpipe. the lsj has the rear in the downpipe and the pre-cat one in the manifold. you can easily go to an exhaust shop and have a o2 bung welded into the downpipe, or pick up the lsj manifold. 07 had the lsj style manifold but, like i mentioned, did not have the oxygen sensor in the manifold. so if you dont already have the lsj manifold, it may be cheaper and better just to get the o2 bung and weld it in (if you have 07, and i guess 08 probably have the same).
