Question for those who made the CMD intake.
So out of you guys that have made the CMD intake with the univeral intake tubing, anyone made this to cold air yet? I have mine short ram and am curious about which parts and degrees would be needed for this.
ok i didnt do the full on CAI but i left in the stock setup from the bumper up and put my filter right next to that so it is getting cold air to it. might not be as ram air effect. I can try to set up a jig to get the proper angles for you if you want.
Originally Posted by bestward27
All you need is a 90, a 45, and a straight piece, and joiners, don't forget you need a spot to put your MAF sensor, i will post pics once my camera is fixed, they may help you more.
i did this to SRI already and it works great. I was inquiring about angles for CAI in the bumper. Often when its hot, i get heat soak
Delta coupe
09-30-2015 08:11 AM
OrangeCoba
09-25-2015 06:06 PM
