Quick Question
Quick Question
Im sure this has been asked before..Is there a How-To out there or anyone know what all I would need to install the 2.4 intake mani on my 06 2.2? I have searced the how to's and there is one for installing it on an 08 model. Just dont know if things would be different between the models.
searchy mc searcherson... its gotta be a round here still i just really dont want to do it for you but you can find it in the how to section 100% guaranteed
Just help the guy. If you have an 06 your going to need the manifold, the o rings, the pcv gasket, brake booster hose and the gasket that goes in between the throttle body and the manifold itself.
Everything you need is in this kit from CED -- including installation instructions:
http://www.crateenginedepot.com/stor...t-W67C144.aspx
People that have installed the 06-07 2.4 manifold and have dynoed to check the difference show an increase in HP/TQ from idle to about 3500RPM and from about 4500-6500RPM (as much as 19 HP above 6000RPM over the stock manifold). The HP/TQ drops a little between 3500-4500RPM without a tune due to the way GM has the fuel enrichment set up.
Yes. The 2.4s also have this lean fuel setup below 4000RPM. On a 2.2 you do not feel any loss when starting from a stop but you do feel it at part throttle at low speed. The real difference is in the top end where the engine obviously breathes better with the 2.4 manifold. You actually get more wheel spin with the 2.4L manifold off the line too...but to reset the learn values after installing the 2.4 manifold make sure to do an erase of the ECM through the OBDII port -- disconnecting the battery does not reset the learn values.
I have already purchased the mani from a user on CSS I was just wondering what else I might need and a possible how to for installing it on an 06 model.
I do appreciate everyone's help!
https://www.cobaltss.net/gallery/fil...arged_2_4l.jpg
2.4 TB needs some tuning to make it work on the 2.2 -- it is NOT a bolt-on-and-drive mod!
If you get a 2.4 tb you wont need the adapter plate or gasket but you will need a Trifecta Tune
Anyone correct me if I am wrong
Is there anywhere I can buy those parts separately?
