quick question
thanks so much... anyone seeing a problem with taking a stock LS exhaust system from a coupe and putting it on a sedan? both 2.2 of course.
i doubt it i believe they have the exact same underbody
Originally Posted by IonNinja
2.25" is not the stock exhaust size
it wouldn't make sense to replace a stock 2.25" system with an aftermarket 2.25" one would it?
Originally Posted by Clmbngfrk18
what do you push up on the car?? i have mine up on jack stands and the rear axle dropped as far as i can and need to go a little more
not sure what else u can do, just cut it...if you need to use it again $20 to have it welded
also yes mufflers could have alot to do with it...but this is more of an economy built car, they aren't necessarily going to put the most optimal exhaust on the car. 1.75" sounds about right to me but I've been wrong before...I've got 2.5" piping and it didn't help me either way so
well the thing is is mkulrey13 needs a stock system to pass inspection in nh so im gonna give him my system plus some cash for his dc exhaust that way we both win but i was trying to do it w\out cutting
Originally Posted by dnbguy86
1.75 for after cat diamter, and before cat is 2.25-2.5
either way, thats good because then I won't need a downpipe for my Pacesetter made...
before the cat is 2.25" or 2.5"?
The piece that comes after the header, but before the cat is 2.5". After the cat but before the rest of the exhaust is 2.25'. Now the the rest of the exhaust is 1.75".
although that 2.25" could be replaced with 2.5" to have me at 2.5" all the way back...I'll probably just leave it as is with the Pacesetter.
