is it really "serviceable" with the engine in the car?
I was going to put this in my last thread but it was asking about peoples rod bearing preferences are. I bought a chiltons manual and have read it but go figure the question I have isn't answered there and there very vague... I need to replace the rod bearings, can I do so with the motor inside? Also is it a must I remove the girdle? The front covers on the motor bolt to it. And it holds the crankshaft in and I don't need that falling out. If someone can shed some light on the easiest way to change these out with the motor in the car please tell. This is really starting to stress me out. That and being told the rod bolts are one time use strech bolts was a nice supprise, seeing the dealer wants over 5 bucks for EACH bolt smh
I think the ecotec build book actually shows how to do this in a decent amount of detail. It's definitely do-able, just not fun.
Around page 19 of the build book.
http://gmtunersource.com/racertech/ecotec-build-book
You'll have to remove the oil pan and cylinder head, but the bedplate (or girdle, as you referred to it as) can remain in place.
See I was trying to avoid removing the head as I have no clue how to time our motor and I don't want to loose timing. Im assuming you guys are talking about actually pulling the piston and rod out. I just wanted to work through the bottom and do one at a time and turn the crankshaft by hand to lower each rod/piston to bottom dead center and chage each then.
I have the oil pan off, then started to take the bedplate off and then read and realized thoes are strech bolts like the head bolts and are a one time use type deal... and I really don't wanna spend 6 bucks a bolt with there being 16 bolts. That gets expensive really fast.. but there oil covered and idunno how well blue locktite will work on em
What happens if you reuse them? Iv asked some people and they just say don't risk it, others said they will eventually come loose. And others have told me they have on motors before they just make sure they torque em correct and a tad of locktite and its been fine for years
any bolt that TTY you need to replace it on reassembly. i dont see how you going to replace a rod bearing without removing the piston. how are you gonna seat the rod bearing in the rod correctly? you can definitly do it with the engine girdle on. doin the timin is easy. they made it dummie proof
The bolt actually deforms when you torque to yield. This is what keeps it in the hole since it slightly changes the thread pitch and locks the bolt in. Replace them and I would see about buying aftermarket ones, even cheap MR gasket ones should be ok since you're not boosted.
I would say not changing any stretch to yield bolts especially on rod bolts is not a good idea. I don't know of anyone that reuses bolts that doesn't have a problem later on. Nothing like watching someones head rise off the block after reusing stretch to yield head bolts. If you are going through all this trouble, might as well do the job right the first time than do it twice.
Highgross89
20
09-11-2015 03:24 PM
Getaway_Driver
40
09-10-2015 09:11 AM
Adam144
09-03-2015 07:48 PM
