rear brake job
rear brake job
soo how the hell do i get the rear drum off. e-brake off. check, taped arround the edge of drum. check.
There is two rubber plugs on the backing plate are these where the auto adjuster are? and if so how do i loosen them to back the shoes off?
Thanks guys
Thanks guys
You just have to muscle them off. The rubber plugs in the back are for the adjuster. Or at least the top one is. If there is a bottom one I don't know what that one is for. You don't need to adjust it before you take it off. If your wheels roll freely then your brake is not applied. If it does not roll freely, then you probably have something broke in there.
i have allready tried hitting arround the drum and the arround the lugs, i have had something wedged between the backing plate and the drum and gave up before the backing plate bent and those damn things still wont come off. i really hate working on drums. much more work the disks haha. so if i start to adjust them off i should be able to just slide them right off no drama right?
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
