Rear drum to Disc???
Hello, Im sure this has been discussed....
Im looking to upgrade my rear drums to disc.
Anyone make a cheap kit to do this???
Or can I just piece-meal the parts from ebay off of an 4 lug disc vehicle???If so is it as simple as the rotors and calipers???
THANKS
THANKS
i think you would have to buy the whole rear axle beam with the calipers and disc brakes already on.
they can be found for not too much, but its not that worth it, as you brake a lot more in the fronts.
That only works if you are wanting to do a 4 to 5 lug swap as well. Either way it's not really worth the trouble as stated and brakes are not an area you want to cheap out on
FYI brakes are in the suspension section of ss.net
Also this is discussed multiple times there. Going cheap on your brakes is not a good idea, but there are a few options out there, it will be around $700-$1000
Intel,
I didn't find this on their website...just a bracket??? their is no spindle to mount a rotor on so this would be a small part of the equation unless I'm missing something..
Powell's website doesn't list any of his cobalt/redline products, you have to pm him or email him or gloria their emails are floating around here somewhere.
Don't know what you mean by not having a spindle to mount the rotor, since the rotor "floats" on the lugs between the hub and rim
agentirons
10-16-2015 03:11 AM
DANRICKARD
10-01-2015 01:08 AM
Delta coupe
09-30-2015 09:11 AM
