Remote turbo????
Originally Posted by Kahless
the silverado kit is only 4k. the install base for the 2.2 is much larger than the 2.0. theres alot more people with the car but will they spend the money.
Vette kit is twin turbos, tuning, injectors, fuel pump, and intercooler.
for cars with higher displacement engines sts is a good idea because there is really no lack of low end torque and you will see a little more lag with this setup. higher displacement engines...this is a VERY good setup if it is done right. i would only reccomend it with a car that has high clearance in the rear end ( i have a foot and 4 inches of clearance from my muffler to the ground and my sts system is going to be about 1/2" higher). they have a snorkle kit for the intake so you dont suck up water and hydrolock your engine. they are actually more efficient than you think, and alot of research and development has gone into their systems. the fastest new model gto in the world is boosted by sts and something like 7 out of the top ten are all boosted by sts.
BAM! http://videos.streetfire.net/search/...8d79b016b3.htm at 9 psi.
i really would not reccomend it for a cobalt or a small displacement engine because the lag will really hurt you there and you really don't have nearly as much flow to spool the turbo, but on higher displacement engines, if you aren't looking for huge hp gains, just a good gain for the money, i'd reccomend it.
