removing the oil pan help!!!
ok i have done everything i need to get my turbo on i have the feed line im just having trouble getting the oil pan off im sure i got out all the bolts its just still really sealed to the motor any have any tricks to get this off!!!???
The sealant almost glued it on mine, pried at it just to find it was also stuck by the dipstick which is a giant PITA to get out.
Our bad solution: Disconnect the dipstick from everything but the oil pan, pry it off with a long flat head or the back of a hammer (It was done..) and take it out dipstick and all.
Also there's a bolt from the A/C that people miss.
Your gonna need to drop the cradle some on the drivers side for clearance too. That is if you didnt loosen it up for the turbo install in the first place.
sSandstorm (06-19-2016)
importkiller
09-30-2015 07:18 PM
