Royal Purple tranny fluid
Hey about how much quarts of tranny fluid does our 2.2 auto tranny take? I just got done installing my zex wet kit with 65shot (75shot once i get my other toys !)...will put on Xtc downpipe, xtc headers (waiting for new ones for the 2005 2.2 to come out since the issue with fitting. I already e-mailed the guy and he said i about a month or so), and Corsa touring once it comes in (I'll get pics and everything you guys like soon, don't worry). Any wayz, i'm changing oil and tranny fluid before a start shooting N2O, just to have it running smooth. Oh, I also just got new tires, michellin pilot exalto. Freakin LOVE these tires!! Definite recommendation to anyone. Sorry. so let me know. Thanks. Oh, also if anyone can help me with this please do...can our cars handle the 400hp or 600hp since our ECUs, or whatever it, hasn't been cracked yet? I mite start my build sometime next year. I already started buying a few parts.
well i mean can it be done with the stock ECU. the build in the gm build book on the 2.2 ecotec is what im talkin about, with 150shot if anything, since there is no turbo kit.
have you read the build book? for the 400hp build, itz not that much stuff...i mean yea itz work work, but no heavy modifitcation. I know itz possible and the build is for our engines, i just need to know if we still need to have our ecu cracked for it...i would think not since most of the power is coming form the nitrous wet kit and it gets its own supply of gas, but i mite b wrong. I have a link to the build book if you wan c it. thanks for your reply though.
There is much more to a nitrous setup than just spraying. There is alot of preporation. Also, you need to have the understanding of how much force is created from a large shot of nitrous like that. This is why GM snapped all 4 connecting rods simultaneously.
Also, I would get a wideband if I were you cause of the issue of closed loop.
Messing with a high shot like that, you need to think about your:
Fuel Pump
Spark Plugs
Connecting Rods
There are many other nitrous related things you need to look out for as well.
As far as reaching 400 HP, you're not reaching that amount of power without doing a motor upgrade and you're defenitley not reaching that with nitrous.
Just do more reading before you start hooking up nitrous kits and changing the nitrous jets.
Originally Posted by HunterKiller89
im not certain but i would imagine some sort of tuning would be needed....or a wideband sensor
along with a new engine....thats gonna need a heavy build...and there will prolly be a turbo released by the time your done with that build
Stock motor can safely handle 75, if you up it you need to get forged pistons, connecting rods and might want to consider better valves, otherwise you'll see a piston fly upward through your hood. If you don't take this advice, carry a camera and record it at all times! (I wanna see a piston shoot)
RIP JL
Wop
Originally Posted by WopOnTour
This is a bit of an Ecotec "myth" I'm afraid. The initial failure was a single rod (beam fatigue near the large end) and the rest was "collateral damage"
RIP JL
Wop
RIP JL
Wop
Next thing you're gonna tell me is Santa Clause doesn't exist...
NO. you guys aren't understanding me. i know what needs to be done to use nitrous. I'm sayin that in the build book it gives you 2 options to achieve 400hp. 1. use the 150shot wet kit w/ a few internal upgrades. 2. use a turbo kit, which there aren't any for our cars yet. Now my question was that with these upgrades and the nitrous kit, does our ECU have to be modified/ cracked?
We are trying to give you sound advice and I'm telling you now, you're not reaching 400 horsepower with 150 shot of nitrous.
Do you understand how a wet kit works? Do you understand what a wet kit is? Do you understand what kind of fuel system you have?
To atleast answer one of your questions, no, you don't necessarily have to have a modifed PCM but you would understand why if you understood how nitrous systems work.
I'm not trying to rip you apart or anything but just point that this might be a bit over your head at this point and you need to stop and re-evaluate what your doing and your plans. Research more. Ask more questions. This is my suggestion to you...take it or leave it.
The reason we are going off base from your original question of transmission fluid is cause you're making it seem much easier than it really is. "150 shot with a few internal upgrades", do you even realize what they upgrades are, how involved it is to do bottom end work, how much these parts cost, what to look for when buying these parts and I could keep going on and on.
well then theres my question again....why not just wait for the turbo since ur not even gonna build the engine for a while...turbo's are 1-2 months away, n tuning wont be too long, though probably more than the 1-2 months for the turbo....i always have seen turbos as a much more cost effective way to get high horsepower...not to mention its constant horsepwer opposed to a shot which only lasts as long as the shot does
A huge shot of nitrous is especially hard on an automatic transaxle, unless you can "stage" it somehow.
But its gonna take more than Royal Purple to bring the 4T45E up to the level required to deal with 350+ lb/ft of TQ. The torque converter will be the least of your worries.In particular the input shaft and input gearset will need to be hardened, omproved clutch plates and likely TCM or other valvebody modifications to get main line pressures up.
After that it's all about beefing up whatever breaks next.
Maybe PM halfcent as I'm pretty sure he has a database of the available sources of parts for the 4T40/45E for his own project car.
Good luck on the build
WopOnTour
WopOnTour
But its gonna take more than Royal Purple to bring the 4T45E up to the level required to deal with 350+ lb/ft of TQ. The torque converter will be the least of your worries.In particular the input shaft and input gearset will need to be hardened and likely TCM or other valvebody modifications to get main line pressures up. After that it's all about beefing up whatever breaks next.
WopOnTour
WopOnTour
