Ruff Idle?
Once it's off, you'll be looking at your throttle body. Remove the 4 bolts holding it in place, unclip the wiring clip, and spray the inside with engine degreaser or throttle body cleaner or brake cleaner, etc. Use a Q-Tip to get at the hard to reach corners, and just clean it all out. Then reinstall
Maybe a 15 minute job
remove the big black thing under your hood...thats part of the stock air box. There should be a clamp holding it in place.
i forgot to mention this, but be sure to remove the throttle body before spraying it with cleaner!
Im sure you figured that much on your own, since i explained how to remove the throttle body, but i noticed i left that little detail out of my directions. You dont really want engine degreaser getting inside your engine after all...lol
