S/C kit?
its made to mate the 2.2 tb to the charger. our tb's are cable in the sunfire/cav. its actually not that hard to bolt up because of the way its designed. its hard to explain ill try to find a pic of it but it has a taper to it. as for bolting up it has 4 holes to bolt the tb to the adapter and 4 separate holes for the screws to mount the adapter to the s/c
Gm # 12590814
That's the part number for the adapter but apparently it is not sold seperately
The best thing to do would be just buy a turbo kit from hahn so then down the road when you want to build your motor you can make some nice numbers with a built 2.2. If you buy the supercharger you are limited in power.
09-28-2015 12:51 PM
