SAI manifold onto a 2003 Ecotec questions
I bought a manifold from a 2007 manifold recently. I was told that all 2007 Cobalts, even the 2.2 are using the LSJ manifolds, correct?
The problem is, this manifold I got has the SAI port on the top center.
I don't believe any 2002-2005 Ecotecs used the SAI set-up, or at least my wife's 2003 Sunfire
does not have any re-routing from the intake box to the manifold that I can see.
I bought this 07 Cobalt 2.2 manifold off of E-bay, and it does not have the D shape port on the downpipe side, so I am guessing that it is an LSJ manifold. Am I correct on this?
The reason I ask is because I want to take the Sunfire in and have the manifold swapped by a muffler shop. I now see that this SAI port on top is going to leak exhaust fumes I am guessing and for another thing, I am worried it wont even fit. If it does leak, do I just simply have someone weld off the SAI port? Maybe just add JB weld or?
I just don't want to pay to have the old manifold removed and then have to have it put back on for nothing.
I need some help on this one guys, your help is definitely appreciated!
If the "2.2 manifold" you bought is welded steel and not cast iron then it is a SAI manifold. Even if you have the top hole welded shut (or make a plate and cut a gasket to seal it) you will still have exhaust gases present all around the manifold plate -- see the open area around the ports where the manifold mounts to the head? IMO I wouldn't use it because of this.
Just for the record....the 07-08 2.2s do not have the LSJ manifold. The 07-08 2.2s use a redesigned manifold but it has a different part number then the LSJ manifold.
A pic of the manifold I have is at this link:
https://www.cobaltss.net/forums/show...t=sai+manifold
It does not look cast. I guess it is not a LSJ manifold, but it sure isn't the POS D shaped port manifold on the older Ecotecs, so the flow is a lot better.
Couldn't I just weld around each port to add enough material so the gasket has a positive lock front to back?
I would also weld the hole, but on the inside and not the top.
While I'm not an expert in this field, I know that new spark plug wires (of basically any kind) are good to install.
Basically, the best wires have the smallest resistance. You can test your current wires' resistance with a voltmeter - check with a professional mechanic to find how many Ohms are allowed before you go spending a lot on replacement wires. Some of the best wires are simply OEM replacements from NGK - if your car is Japanese. They're a lot cheaper than the much-hyped 8mm 'performance' wires you see in the magazines, and probably perform just as well.
