Secondary Air Injection on late production 2006 L61's
Old 11-15-2008, 01:43 AM
  #376
Maven's Avatar
If you suck in water youll burn out the AIR pump. This is actually a common issue, that why GM went to the trouble of making the AIR system breathe through where it does.
I would try using some self vulcanizing tape. it only sticks to itself, so no gooey mess after a while, its thicker than electrical tape, and tends to have a much higher temp rating.
There are also self adhesive silicone sheets available at some parts stores, that would work nice too.
Old 11-15-2008, 07:23 AM
  #377
TheDaves413's Avatar
Awesome, thanks for the help guys.
I have noticed a big loss in MPG lately, I thought the two might be connected some how. If the air pump is broken would it cause any noticeable changes in the cars performance?
Old 11-18-2008, 11:11 AM
  #378
blackbolt89's Avatar
from my limited knowledge on the subject i would say no, based on the fact that it only feeds air into the exhaust to clean up emissions. but i'm no expert.
Old 11-18-2008, 11:34 AM
  #379
D4u2s0t's Avatar
Originally Posted by Halfcent
There is no extra O2 sensor. You don't have to plug anything.
Originally Posted by Maven
If you get a header youll have an O2 sensor in the header anbd one after the cat. No issues.
SAIR cars dont have EXTRA O2 sensors, they just moved the "before cat" sensor out of the manifold and into the downpipe.
i've worked on several cobalts that had 3 02 sensors.
Old 11-18-2008, 12:03 PM
  #380
Maven's Avatar
Every stock Cobalt/G5 Ive ever worked on or done a PDI on had had exactly two O2 sensors. Theres no DTCs to support a 3rd sensor, and there mention of a 3rd sensor in the service manual from 2005-2009.
You talking about cars with a wideband?
Old 11-18-2008, 12:17 PM
  #381
D4u2s0t's Avatar
no, stock cars. one guy I had to send home because he had one on the manifold, and 2 on the downpipe, one before the first cat and one after the 2nd cat. I told him i wasn't going to leave one of the 02 sensors dangling or just disconnect it. Unless someone that owned the car before him drilled a wideband bung, and plugged it with a sensor but without a guage, but that would seem odd for an otherwise 100% stock car.
Old 11-19-2008, 12:16 PM
  #382
I'm old school
Halfcent's Avatar
It seems redundant to have one on the manifold and just before the cats. That would be measuring the same air twice. Sounds like he had either the manifold or downpipe replaced with the wrong part at some point before it got to you. Did all 3 holes have a sensor screwed into it, and where they actually hooked up to something?
Old 11-19-2008, 01:14 PM
  #383
D4u2s0t's Avatar
yes, all 3 were screwed in. Didn't check if they were actually hooked up, never needed to go that far.
maybe they put a regular manifold, and the downpipe for sai? only other thing I can think of.
Old 11-19-2008, 01:48 PM
  #384
Maven's Avatar
Must have been....Ive seen stranger things happen, but I am positive tjhat there arent 3 sensor Cobalts from GM
Old 12-28-2008, 07:58 PM
  #385
organic E's Avatar
Alright just to sum this up. I live in PA I have no emissions but visual where I am at. I have SAI on my 08 LS. I have OBX header, GMPP intake and breather, and SES code for SAI. How would I best go about haveing my Step Dad who is Service Director at my local Chevy dealer, who has access to Tech2 reflash my PCM so that I dont have SES light any more. What do I need him to change to get the light out. Can I have him update my PCM with a none SAI program and call it a day.
Old 12-28-2008, 10:18 PM
  #386
I'm old school
Halfcent's Avatar
Well, yes, he can do it. And he should know full well how to do it without you needing to ask the internet. Just ask him. But I don't need to retype everything in this thread for you. JUST READ POST NUMBER 1! It has the instructions.
Old 01-21-2009, 01:53 PM
  #387
i know that no one has been on here in a while but i still wanna show my act of triumph over this god damned SAI system!
Old 01-21-2009, 02:59 PM
  #388
D4u2s0t's Avatar
i did that like 2 years ago
Old 01-21-2009, 03:35 PM
  #389
oh psh, i bet mine looks better :P
Old 01-26-2009, 04:40 PM
  #390
2006cobalt2.2's Avatar
so i was dumb and didnt do enought research before i bought my header, and it turns out my car has sai. If the sai only runs on start up, wouldnt i just be able to leave it unplugged from the header instead of removing the full system?
Old 01-26-2009, 09:45 PM
  #391
i'm not too well educated on this stuff but i'm pretty sure that'll set a CEL. one thing you can do though is to have a GM dealer reflash your computer to the sai-less codes. but i'm not too sure. one person that will know about this situation is 1/2 cent. look to post 1. PM him, he can tell you more.
Old 01-26-2009, 11:04 PM
  #392
but is gm willing to do this? if so how much
Old 01-27-2009, 11:41 AM
  #393
I'm old school
Halfcent's Avatar
While your car will physically work fine, you will get a CEL. That is exactly what this thread is trying to tell you. Your options are to not install that header, or get the reflash.
GM will not do the reflash for you as an official service request. You have to make friends with a tech that is willing to do the reflash for you. The program is completely legit and your car will work perfectly. GM won't do it because of they can't know what state you plan to drive in.
Old 01-27-2009, 01:41 PM
  #394
how about a trifecta tune? would that work or only a gm reflash?
Old 01-27-2009, 03:44 PM
  #395
I'm old school
Halfcent's Avatar
That I don't know. I have not yet heard of anybody using Trifecta to make this kind of change. It would seem reasonable that they should be able to do it.
Old 01-28-2009, 01:09 AM
  #396
k, ill look into it, but im prob just gonna remove it and have a cel for now. Wont hurt anything right?
Old 01-28-2009, 08:17 AM
  #397
I'm old school
Halfcent's Avatar
Correct. Just don't expect to pass any state required emmisions tests. I do not recommend going forward without having a tuning option already in place. But if you are going to, you might as well completely remove the entire system. The pump, air lines, brackets, it will all be just useless weight.
Old 01-28-2009, 01:16 PM
  #398
im in florida so no emissions for me. im gonna see if i can talk someone at chevy into doing the reflash for me then go from there
Old 01-28-2009, 02:47 PM
  #399
Sarbae's Avatar
I thought Florida emissions was almost as bad as CARB?
Old 01-28-2009, 10:50 PM
  #400
no, theres no testing here. Hell, if they did start testing i think over half the cars around here would fail lol. Cops dont even car about loud exhaust, smoke coming from peoples exhaust. A couple cops in the area are even running catless systems on their cars.
Quick Reply: Secondary Air Injection on late production 2006 L61's
