Sentry's Turbo Build Thread Extravaganza!
#328
I don't get what's going on here, is it missing, or bogging, or what? This is just a suggestion, but maybe you should put your stock injectors back in, and try to fire it up, DON'T run it like that for long, but that will atleast tell you if the problem is fuel related. Is your check engine light flashing? Did you try different plugs? Maybe check your fuel pressure with a guage, that may clue you in on injector problems. How bout putting the stock tune back in it, then try to fire it up to see if it's tune related, again, i wouldn't run it long like that unless you have a wideband. Maybe you have a bad turbo. What is your vacuum reading while idling? Sorry, i'm just brainstorming for you, good luck!!!
#332
I Got the Plug out!
i have to settle with the one closest to the drivers side though.
the one on the passanger side no way it was coming out, the vice grips just spun time after time, and the one in the middle the hose wouldnt get to it..
#333
I've got all day tomorrow to work on it, or today rather, so expect it running tomorrow night for sure.
I haven't had a lot of time to mess with it, been really busy this week with family, gf, etc.
#337
hey you ever find out whats wrong with your car ? i finally got mine back together and tunned and it wont run it starts for a few seconds and shuts off what exactly is yours doing
#340
it only idles between 1-2 k for a few seconds and then shuts off by it self ... im in the process of doing a compression test .
#348
i may try to start the car with the stock injectors and see if it atleast runs . yea vince is workin with it .. but it starts runs for a few seconds if you hold the rpms steady around 2-3 k then shuts off
#349
Think it could be in the tune? I'll email vince.
